Engine offset, '69 f100 302
Old Apr 4, 2020 | 05:41 PM
Jon Richard's Avatar
Jon Richard
Motor favors the P side in the engine bay. Appears to be that way on purpose judging from the shape of the floor pan of the cab and how centered the fan is in the shroud.
I'm having a header clearance issue and if I could scoot the engine towards the center even a little it would help.
Is there some motor mounts available or has this been tried by any of the members here?
I would ofcourse be mindful of opinion angle.
Old Apr 5, 2020 | 08:38 AM
Lrrr-RulerOfOmicronP's Avatar
Might be able to shim the motor mounts. Replacing them might help I they are wore out. I don't know how nice of a ride you are building but denting the headers does not make much difference for hp. You might be able to heat the header and bend it over.
https://www.hotrod.com/articles/engi...-dont-have-to/
Old Apr 5, 2020 | 12:47 PM
Jon Richard
you know working the header would normally be my preference but I spent some coin to have these ceramic coated inside and out. If I bend it I'll do it cold. I want to do like you say and replace the motor mounts and cheat it to the D side as much as I can.
Old Apr 6, 2020 | 10:51 AM
Freightrain's Avatar
Freightrain
Being a 302, you could put a 1/4" shim above the mount(between the block and mount), raising the motor slightly to gain some room. You can then also shim the transmission mount the same amount to keep the driveline angle the same.
Doing only the passenger side might help tilt it more? That slight bit would likely not effect anything else. Or do 1/4" on drivers and 3/8" on passenger?
Old Apr 6, 2020 | 11:17 AM
Jon Richard
I'm thinking about shiming the P side between the motor mount and engine perch. It's at a 45* in relation to the chassis so I'm thinking a 1/2" spacer there will raise the P side 1/4" and nudge the motor to the D side 1/4".
also there seems no polyurathane motor mounts available for a bump with a 302. Looking at Bronco motor mounts, they appear to raise the engine 1/2".
Old Apr 6, 2020 | 02:57 PM
robertrpeak's Avatar
robertrpeak
If all else fails, I'd cut a notch in the frame member, that and maybe pull the trans tailend over towards the driver side a bit.
Old Apr 6, 2020 | 03:15 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
Have you put tranny on and mounted to rear cross member? It may raise it up away from front cross member.
Old Apr 6, 2020 | 06:36 PM
Jon Richard
if all else fails that is exactly what will happen, just checking if it can be avoided as I haven't done any cutting or welding on the truck yet-trying to keep it at least sort of virgin.
this was next then came the rain, but also need to do it to check alignment angles- tailshaft might need to go that way to line up hopefully.
The headers are for a Falcon ( Doug's D660YA ) and there's lots of room on the D side. The trans mount is off center from the factory about 1 3/8" to the P side. The pinion is offset 1 3/4". These are all rough tape measure measurements.
Old Apr 6, 2020 | 06:50 PM
GPatrick's Avatar
GPatrick
Before you mess up your drive line angles, I'd use some percussion engineering and get the clearance you need - unless the headers have some high dollar ceramic coating. If you can tolerate a few commercials, watch this video on the power loss due to dents in headers - https://www.dailymotion.com/video/x3vupq0
You can also get everything installed properly on good mounts and do some gentle prying with a 2x4. You only need a quarter inch or so.
Old Apr 6, 2020 | 08:21 PM
Jon Richard
I agree, infact at this point for me it has become about checking and correcting if need be the driveline alignment, and figuring out how to make the rest conform to it.
I'm going to try a set of aftermarket Bronco motor mounts that may raise the motor 1/2"-3/4".
woodmanwoody
Jan 31, 2020 05:45 PM
1tonner
Ford Truck Parts for Sale
Jun 2, 2017 12:03 PM
danny56555
Feb 13, 2015 05:52 PM
54TexasF100
Dec 28, 2011 07:13 PM
fordkid16
Apr 19, 2009 07:31 AM
