Motor level HELP
Old Feb 13, 2015 | 09:53 AM
danny56555's Avatar
danny56555
Exclamation Motor level HELP
I recently swapped out the 460 out of my 68 F-100 and put a 302 in and it is sitting at about 3 or 4 inches to low in towards the back of the motor. Suggestions on what the problem could possibly and a solution would be greatly appreciated.
Old Feb 13, 2015 | 11:40 AM
BobbyFord's Avatar
BobbyFord
Which engine stands do you have?
Old Feb 13, 2015 | 01:28 PM
danny56555's Avatar
danny56555
The stands are from a 67 F-100 that previously had a 302
Old Feb 13, 2015 | 02:20 PM
JEFFFAFA's Avatar
JEFFFAFA
Sounds like someone used the wrong stands in that 67 and now you have them.
Old Feb 13, 2015 | 02:24 PM
fe390pc's Avatar
fe390pc
Could be the Transmission cross-member was modified as well.
Old Feb 13, 2015 | 04:11 PM
351Cleveland C4's Avatar
351Cleveland C4
Isn't the engine supposed to be tilted rearward? 3-4" sounds drastic but I don't think it's supposed to be flat.
Old Feb 13, 2015 | 04:52 PM
ultraranger's Avatar
ultraranger
Good chance you're correct since 302s didn't come in a '67 pickup. --302 wasn't factory installed in the trucks until mid-year 1969.
Old Feb 13, 2015 | 05:52 PM
BobbyFord's Avatar
BobbyFord
6 cyl and 352 were the only engines available in a 67 but both use the same engine stands. You need 302 stands from a later truck.
4 to 5 degrees, tail down is what you want.
Comparison Photos of Engine Perches - FORDification.com
Fetruck86
Apr 18, 2016 07:32 PM
SIRed
Jun 19, 2013 01:40 PM
sgt.bigjim
20
Apr 23, 2013 03:12 PM
