Ford 361FT Gasket Set and Exhaust Manifold Trials
I'm having a really tough time finding a gasket set for the 361FT in my F600 1978. Need at least the manifold gaskets maybe the heads if that's the only way to get the manifolds off. Are there cross referenced ones or does likea a 330 or 390 kit work? NAPA doesn't show any gaskets what so ever for the 361ft, and a lot of what I'm finding on the internet might say it's for a 361 but when you look at it it says it's a 330 set. Also if anyone has tricks to pulling manifold bolts let me know, it's a bane right now of my existence, got one bolt out, broke another off, the others aren't budging .
Thanks for the help
Thanks for the help
Thanks for the help
Thanks for the help
Thanks we ended up taking the heads etc off and then got the bolts out once everything was outside of the truck.
Any recommendations on bolts to put them back in? Don't know if folks use brass still or stainless etc that might not be such monsters if I ever had to take them out again!
Thanks
Thanks
Thanks
Thanks
Looking now for an intake manifold gasket as the kit I got I was told was an FT kit but was apparently an FE gasket kit. Do you know if the head gaskets are the same for each as we put the ones in the kit in, should I pull them off and get FT head gaskets or does that matter at all?
Thanks
Erik
Thanks
Erik
The head gaskets were no different between the two engine series, I don't think. Maybe in terms of composition to withstand high combustion temps? Intake and exhaust gaskets are different, yes.
Side note: My memory is fuzzy, but I seem to recall the FelPro conversion gasket set (top end) included the 330MD exhaust gaskets.
Years after I did that, I read a Ford service bulletin or somewhere in a Motor's manual maybe, where they said to use anti-seize the same way I did.
I agree the steel is better with the stock manifolds, as long as the head and manifold are straight. I used to take a composite 330FT exhaust gasket and cut it to fit my headers, but that's another story
Johnny Be Cool
17
04-03-2016 10:11 AM
james gang 1001
03-17-2010 01:36 PM
ChunderDownUnder
13
06-28-2009 05:24 PM
