7.3 misfire and P1316 code
Old Apr 3, 2020 | 01:05 AM
Ogsweatyyeti's Avatar
Ogsweatyyeti
Hey y’all I’m new here and my truck is giving me fits. For the past fews weeks while driving my engine would start to misfire a bit and the check engine light would come on. Three seconds later it would run fine and the light would go off. Two days ago it started to run really rough and the check engine light stayed on while the truck was running. I took it to a local shop and had them pull the codes. Codes are:
P0603 - Internal control module keep alive memory error.
P1316 - Ignition driver monitor codes detected.
P1139 - Water in fuel indicator lamp circuit malfunction.
B2658 - Wait to start earning indicator circuit open.
U1267 - SCP data fault from J1850 Bus.
I’ve read and watched videos on the P1316 until my eyes bled and assumed that the majority of the problem starting there. So today I replaced the UVCH and glow plugs. Fired it up and it is now running worse. Any ideas of what the heck is going on??? Help is much appreciated!
Thanks in advance!
Justin
Old Apr 3, 2020 | 06:27 AM
FordTruckNoob's Avatar
FordTruckNoob
Before you go replacing parts in an attempt to fix that P1316, ohm out the harness at the IDM connector. A short in the circuits will kill an IDM very quickly.
Old Apr 3, 2020 | 06:44 AM
slowsure's Avatar
slowsure
Also inspect the underside of the Harness that leads to the Driver side 42 pin connector. It can chafe on the valve cover and cause all sorts of problems.
The above is a cut-n-paste from @aawlberninf350 in another similar thread posted yesterday.
It refers to the harness that comes from the IDM to the drivers side big 42 pin connector.
Old Apr 3, 2020 | 06:48 AM
FordTruckNoob
This is the thread slowsure was talking about.
https://www.ford-trucks.com/forums/1...1316-code.html
Old Apr 4, 2020 | 12:11 PM
Ogsweatyyeti
Thanks fellas. I’m about to start digging back into it today. I’ll let you know the results.
Old Apr 4, 2020 | 12:41 PM
HD Rider's Avatar
HD Rider
Just wondering....
What brand of UVCH did you use?
Old Apr 4, 2020 | 08:50 PM
Ogsweatyyeti
Originally Posted by HD Rider
Just wondering....
Probably not the best. They are a Dorman brand from Orielly. Just an update, I did not end up tearing it apart again today.
Old Apr 4, 2020 | 11:44 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
From what I read the Dormans have improved quality since they first came out. They were a point-and-laugh item but now it's just a little side-eye. Probably work just fine.
When the truck ran poorly was is raining? Cross any streams? The IDM can get water inside if you get in too deep.
Did the codes get cleared?
Old Apr 5, 2020 | 05:05 PM
Ogsweatyyeti
I’m finally back under the hood and was going to test the IDM harness but mine looks nothing like this.
Old Apr 5, 2020 | 05:07 PM
FordTruckNoob
That's the PCM connector. The IDM is hiding behind the splashguard inside your driver side fender.
Old Apr 5, 2020 | 05:19 PM
Ogsweatyyeti
Nevermind. I unplugged the PCM. Found the IDM and gonna test it now.
Old Apr 5, 2020 | 06:49 PM
Ogsweatyyeti
So here is what I have found. All of the power feeds to injectors ohm out at about 2.8 ohms.
Left bank IDM ground circuit reads 0.00
Right bank IDM ground circuit and both injector ground shield tests won’t give a reading.
Any idea where the short may be? I have inspected everything near the valve covers and it they seem to be good. Thanks in advance.
Old Apr 5, 2020 | 06:58 PM
FordTruckNoob
You'll have to work your way in from the IDM connector to find where the short is I'm afraid. At least you now know it's in the left bank.
Old Apr 5, 2020 | 07:16 PM
HD Rider's Avatar
HD Rider
I'm betting the problem is under the valve cover.
billy34522
Jun 15, 2018 09:13 PM
VNV Jess
Apr 25, 2014 06:46 PM
cuttn4fun
Feb 26, 2013 10:14 AM
Schuby
1997 - 2003 F150
Mar 3, 2010 10:42 AM
firemanp
Aug 22, 2008 08:36 PM
