Third Brake Light Melting Issue
Old Apr 1, 2020 | 10:12 AM
GasGuzler's Avatar
GasGuzler
Question Third Brake Light Melting Issue
I have a 1996 Ford F-150 and the third brake light wasn't working. I just assumed that the bulb was burned out so I unscrewed and pulled out the light housing to check. Pretty much everything was melted (the bulb, the bulb socket, and part of the housing) so I had to get a whole new third brake light. I've had this exact issue with almost every OBS Ford I've owned that had a third brake light so this isn't the first time I've experienced this. I don't know what causes this or how to fix it so I'd really appreciate some help.
This isn't my picture it's from the internet but this is exactly what happened to mine.
Old Apr 1, 2020 | 10:19 AM
Conanski's Avatar
Conanski
You have a really bad habit of driving with both feet?
Old Apr 1, 2020 | 12:22 PM
95fiveoh's Avatar
95fiveoh
Its a really common problem. The plastic just doesn't take the heat of the bulbs if you have the lights on for a long time. All I've been able to do is find the least melted one I can in the junkyard. You can put some LED bulbs in them which stay a lot cooler and help prevent it melting any more. CPAddict has an OE style replacement in the works but no release date on it yet. I've found the LED ones from LMC and the like are fairly low quality.
Old Apr 1, 2020 | 12:24 PM
torq'ta 5 8's Avatar
torq'ta 5 8
some LEDS play mind games with computer, when it tries to control E4OD, trans
Old Apr 1, 2020 | 04:55 PM
White 97 xlt's Avatar
White 97 xlt
That problem can be cured with a load resistor... Gotta make the computer "think: there is a real bulb in there!!
Old Apr 1, 2020 | 07:11 PM
torq'ta 5 8
know what value
Old Apr 1, 2020 | 07:45 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
know what value
It's probably not that high, to get close to spec maybe take your average third brake light bulb and ohm it out, I'd imagine somewhere between 2-6 ohms is a decent guess
Old Apr 1, 2020 | 08:18 PM
torq'ta 5 8
Thanks, just never seen anyone post a #, amp draw is 1.4amps so ohms law ciphering gave me 8-8.5, close enuff fer the girls we go wit
Old Apr 1, 2020 | 09:27 PM
TexasGuy001's Avatar
TexasGuy001
Unfortunately this is just the nature of this lamp with stock incandescent bulbs. The only fix I have found is getting a nice one and using LEDs. If you don't have LEDs in the tail lights you should not need a resistor for just the third brake light. Make sure the transmission shifts correctly, torque convertor locks up as it should, and cruise control works. If so, it is fine. I used this LED in red (LED color should match lens color) from superbrightleds.com Part number 921-R19-T.
https://www.superbrightleds.com/more...car/1563/3622/
I hope the CPaddict reproduction is good, since the other aftermarket LED lamps are junk and ugly.
Old Apr 1, 2020 | 09:55 PM
95fiveoh's Avatar
95fiveoh
Do you have to worry about the LEDs with a stick truck?
Old Apr 2, 2020 | 06:11 PM
torq'ta 5 8
narry a bit
Old Apr 3, 2020 | 04:22 PM
95fiveoh's Avatar
95fiveoh
narry a bit
I'll have to pick some up. I think about the light melting everytime I have the doors open for any length of time doing interior work or whatever it may be.
tim nick
Escape & Escape Hybrid
Dec 28, 2015 09:07 PM
rmalottwtes30
Nov 9, 2005 05:57 PM
MustangGT221
Aug 15, 2005 05:47 PM
BlueOvalFitter
1997 - 2003 F150
Oct 18, 2003 04:48 PM
fordblue_ca
Apr 1, 2001 07:08 PM
