Sponsored by: Real Truck
Convert-a-ball
Old Mar 31, 2020 | 09:27 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Convert-a-ball
So I've seriously had it with keeping two drop hitches in the bed of my truck everday. Plus if I'm at my dads place I need a 1 7/8 for his two little trailers...today I swapped between the 2 and 2 5/16 a least six times movingvtrailers around!
So I was looking and found the convert-a-ball system, anyone use it? I WILL NOT spend $200 plus on one of them b&w or maxxtow etc so I figured the convert-a-ball at $80 bucks is a nice deal. Plus I could use one of the six drop hitches I have still LOL
https://www.convert-a-ball.com/
https://www.etrailer.com/Hitch-Ball/Convert-A-Ball/902B.html
Old Mar 31, 2020 | 09:49 PM
ford390gashog's Avatar
ford390gashog
If l the trailers are small I see no reason not too. The 10k limit excludes all but one of my trailers.
Old Mar 31, 2020 | 09:57 PM
moymurfs's Avatar
moymurfs
I used them a while back. It was ok for a while but it got tedious and the the pin that secures the ***** begins to rust..then I got dirty...greased it...then I got greasy. I just use the hitch that has the 3 ***** on it and you rotate it to whichever size you need.
Old Mar 31, 2020 | 10:33 PM
Oredigger's Avatar
Oredigger
I just swapped out the tongue hitches on my trailers to all 2-5/16. Looks a little ridiculous on my boat which is probably only 3k with the trailer, but no switching for me. Fleet supply sells them for about 25 bucks. Depending how many trailers you have might be easier way to go.
Old Apr 1, 2020 | 08:51 AM
WWR's Avatar
WWR
The Curt 45900 is very heavy duty and reasonable at $124, and gets you 2" and 2-5/16. I own several.
https://smile.amazon.com/CURT-45900-.../dp/B004SMGAJ6
I feel your pain OP, I absolutely refuse to let 1-7/8 exist in *my* world. I swapped my little TSC trailer to 2" the day I got it, and I'm doing the same for a friend as soon as I finish up some orders. They should just abolish 1-7/8" and make 2" the lighter duty standard and 2-5/16 the heavier standard.
Old Apr 1, 2020 | 12:40 PM
RV_Tech's Avatar
RV_Tech
I've use the same thing for years. cheap and never a problem.
Old Apr 1, 2020 | 05:00 PM
Veltech's Avatar
Veltech
I have the convert a ball and like it, make sure you buy the heavier rated one. They dont seem to like the ball being stored outside, pin will hang up (my dad had that problem) I store mine in truck when not in use and havent had any problems with it
Old Apr 1, 2020 | 08:11 PM
dirthawg's Avatar
dirthawg
If you are just moving trailers around couldn't you just use the 1-7/8" ball to do all that? No need to lock the coupler to the ball unless you get on the road.
If the tongue weight is correct it won't come off the ball unless you hit a large bump, the safety chains will prevent the trailer from hitting the ground.
Old Apr 2, 2020 | 12:26 AM
Old Turnkey's Avatar
Old Turnkey
I am by no means the safety police, but if so inclined might wanna check your state laws to see if two piece hitch ***** are legal.
Old Apr 2, 2020 | 10:56 PM
SuperDutyScaler
I was looking at this actually, seems like a perfect fit for me. And my dads little utility trailer already has a 2" coupler on it's way LOL
Old Apr 3, 2020 | 07:14 AM
gpeade's Avatar
gpeade
This is what I did. Granted the only trailer I have with 2 5/16 is my camper and that has it's own drawbar but everything else I changed the coupler to 2". Now I never have to remove my drawbar unless I'm going camping. Me personally I feel by the time you switch the convert-a-ball thing all around you could have just swapped drawbars. But that's just me.
Old Apr 3, 2020 | 10:52 AM
WWR's Avatar
WWR
I initially invested in separate, SOLID forged draw bars in 2", 4, and 6" drop with 1-1/4 shank 2-5/16 *****. If anyone has purchased the "good stuff" like this you know it ain't cheap - we're not talking the hollow tube crap at AutoZone with welds with no body and smaller shanks.
I bet I've got at least $325 into three solid forged draw bars with the good *****. And even then I'm committed to only one amount of drop.
I wish I would have got the Curt setup from the start 'cause it encompasses the two common ball sizes and allows tons of adjustability for drop OR rise, and is rated as high as anything else bumper-pull-wise. Sometimes rise is nice if ya gotta use your 1/2 ton in a pinch just to jockey a deckover around the yard or something
MrOneEyedBoh
Oct 17, 2019 02:33 PM
Ben Marshall
1983 - 2012 Ranger & B-Series
Oct 18, 2008 11:55 AM
mrfox0246
May 23, 2007 01:51 PM
socalfurnow
All Things Towing
Mar 22, 2006 03:48 PM
f350xlt460
Dec 15, 2003 09:37 PM
