e4od rough shifting
Old Mar 31, 2020 | 06:38 PM
Maxime Beaulieu's Avatar
Maxime Beaulieu
e4od rough shifting
hi i got a 96 f250 with a 7.3l and my transmition shift rough in 2and3 guear if this already happen to someone and can let me know wich sensor or plugging i have to change to stop that
Old Mar 31, 2020 | 06:53 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You have to change the one that has a problem. The way to know which one this is, is to read the codes. Forscan can do it, or a good independent shop, or a Ford dealer.
Old Mar 31, 2020 | 06:55 PM
Walleye Hunter's Avatar
Walleye Hunter
Welcome to FTE, Maxime, there is a section of this board dedicated to your year of truck where you can probably get better help. Our trucks have the next generation trans from the e4od and are not the same. However, there is a former trans engineer who visits here and he may be able to help you. Maybe a mod can move this to the appropriate forum for you. Good luck.
Old Mar 31, 2020 | 07:00 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@Maxime Beaulieu , I have moved your thread to the appropriate sub-forum. Good luck with resolving your issue.
Old Apr 1, 2020 | 03:15 PM
Maxime Beaulieu
thank you i just begin in those truck and in this forum 😅
Old Apr 1, 2020 | 03:17 PM
Maxime Beaulieu
i already heard that it can be the ebp sensor or something like that but not sure
Old Apr 1, 2020 | 03:50 PM
96XLTczny's Avatar
96XLTczny
https://www.ford-trucks.com/forums/1...-question.html
https://forscan.org/download.html
Use your search button for more Forscan info.
Old Apr 1, 2020 | 04:15 PM
Mark Kovalsky
You're right, it's something. If you want to know which something it is you need the codes.
Dutter 2
Dec 4, 2016 04:42 PM
max harris
Oct 3, 2015 11:04 AM
