c6 transmission maintenance
Old Mar 31, 2020 | 02:37 PM
Michael Molzberger's Avatar
Michael Molzberger
hello
since half year im owning a ford f350 from 1979 with 460cui and c6 transmission from arizona. the transmission worked well until my trip to finnland in january this year. then happens burned clutch and friction plates which means now forward moving anymore. the repair has done there propperly but now after about 2000-3000 miles driving i have feeling that there is some little changing in shifting gears. maybe its only feeling but is there any need to adjust the intermediate band after short periode of driving? i think the complete overhall was made very professionell. what is the real torgue need for intermediate band setting, best i can work is nm. the us units are not so common for me and i noticed that there is some different notes in www.
as i told its maybe only feeling from myside.
but by the way its a very great truck and hole family love it.
thanks in advance
best regards michael
Old Mar 31, 2020 | 03:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Loosen the locknut
tighten the adjuster to 13 1/2 nm
back off exactly 1 1/2 turns
hold adjuster so it doesn't turn
tighten locknut
Old Apr 3, 2020 | 02:16 PM
Michael Molzberger
hi mike,
thanks for that info. will check tomorrow.
kindly regards
michael
Old Apr 5, 2020 | 10:15 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
use a new lock nut for leaks. you can use a setting of 1 to 1.5 turns OUT from the 10 lb/ft initial torque. 1 turn is ok too.
1984Supercab
Jun 18, 2018 12:11 PM
gas6999
Feb 27, 2015 06:04 PM
mitchell390
Dec 18, 2011 01:02 PM
fordsrgrt
Apr 22, 2009 04:32 PM
Crazy Canuck
Aug 16, 2002 03:54 AM
