2020 excessive DEF fluid consumption
Old Mar 30, 2020 | 09:31 PM
Snowtower 2's Avatar
Snowtower 2
I had to add fluid allready at 2200 miles due to the countdown alarm. I added 2.5 gallons which netted me another 300 miles it looks like.
Something must be wrong when I see the attached info while still showing over a half of a tank. I used plenty on my old 17 6.7 but not this much.
Anyone have any thoughts or similarities on their 2020?
Old Mar 30, 2020 | 09:38 PM
mattymax's Avatar
mattymax
Are you towing or just daily driving
Old Mar 30, 2020 | 09:44 PM
Snowtower 2
I have approx 1500 miles towing so far. Getting between 9-12 mpg while towing on long trips. The countdown shouldn't start while still showing over half full in my opinion...
Old Mar 31, 2020 | 11:17 AM
jimd1050's Avatar
jimd1050
BuhBye F450, I'm relaxin'
A.) The Gauge is terrible B.) I wouldn't necessarily trust the calculated "miles" value and C.) Towing literally "EATS" DEF! I had been daily driving my F-450 for almost 2 months before our 33 day, 3200 mile camping trip, carrying our 5600lb truck camper, and the gauge sat at 1/2 the entire time. I added 5 gals when we were ready to leave, which brought it to "Full"! When we got from MA to Daytona, FL (~1600 miles) I had to put 7.5 gals in the tank (and it took every drop). My 2019 doesn't show the calculated "Miles to Empty" - either that or it's because it's only an XLT! That's my take on the situation!
Old Mar 31, 2020 | 11:59 AM
senix's Avatar
senix
Probably this issue really is the fact that it was not full to begin with. Even though you have a guage it is till just reading probes
Do a complete fill using the ford spout that prevents over filling. Then maybe it will reset properly.
Old Mar 31, 2020 | 12:13 PM
Rich53's Avatar
Rich53
I kept track of every gallon of DEF I put in my 2012 F250, don't have any miles to speak of yet on my 2020.
Towing a 10K boat and trailer, i would get about 10.5 MPG, and would burn a gallon of DEF every 700-800 miles.
Without a trailer, I burned about 1 gallon every 1200 miles, sometimes a bit better.
Over 80K miles, keeping track of all of it, fuel and DEF, my usage rate was 1.26%.
My understanding is that the big over the road trucks use more like 3%.
You could run the numbers and see where you fall in the range, but you do need to start with a verified full tank and then keep track from there, you can't rely on the dealer having really filled it, etc.
Old Mar 31, 2020 | 12:16 PM
rustyshakelford's Avatar
rustyshakelford
whats this ford spout you’re talking about? I don’t remember my 17 having anything
brett
Old Mar 31, 2020 | 12:26 PM
Rich53's Avatar
Rich53
All the Def bottles come with a spout that is supposed to stop the flow when it is full, the Ford one seems to work better than most. It comes with the bottle of Def you buy from Ford.
i use the blue Def 2.5 gallon jug, it has a spout as well, if you believe it is full when it stops, it works fine. If you are like me and just try and see if it will take more by tilting the bottle back, which lets air back into the bottle, it will overflow and you have to rinse it off.
someday I will learn.
Old Mar 31, 2020 | 12:27 PM
75Mike's Avatar
75Mike
brett
https://www.amazon.com/gp/product/B008B5WVF8/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B008B5WVF8/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
Old Mar 31, 2020 | 12:58 PM
Snowtower 2
Well, I will fill it up and see how much it takes to verify the gauge somewhat. In the 70k miles on my last one I could get 3500-6000 miles on a tank. I assumed this one would be simular...
Old Mar 31, 2020 | 02:42 PM
senix's Avatar
senix
The ford spout is the best and is re-useable. No drips, complete seal and works with other brands/containers.
Won't let you over fill, very important in cold freezing temps, and is reuseable.
Shaun Fed
6.7L Power Stroke Diesel
22
Mar 5, 2020 06:15 PM
otto1990
Feb 25, 2020 06:19 AM
FONRDAY
Jan 30, 2020 10:20 PM
1981 F100
Nov 21, 2018 06:26 AM
Antacus
Oct 6, 2005 10:30 PM
