C4 fluid capacity
Old Nov 19, 2018 | 06:38 PM
1981 F100's Avatar
1981 F100
Question C4 fluid capacity
How much should I put in, before starting the truck? Convertor has maybe a quart in it yet, we drained as much out as we could before putting it in. Has a shallow pan, how much fluid to totally fill it?
Old Nov 19, 2018 | 07:31 PM
82_F100_300Six's Avatar
82_F100_300Six
I have no idea but I would put enough to show on the stick, then run it, put it in gear and stuff. then add it a little at a time to get it in between the hash marks with some driving as well (fluid hot)
Old Nov 20, 2018 | 06:05 AM
81F(ranken)100's Avatar
81F(ranken)100
Old Nov 20, 2018 | 06:38 AM
1981 F100's Avatar
1981 F100
Thanks! So if I poured maybe 5 or 6 quarts in before starting the truck I should be good
Old Nov 20, 2018 | 02:59 PM
FuzzFace2's Avatar
FuzzFace2
I pour it in till I see it just above the full mark, don't worry it will drop once it is running.
I then start it looking for leaks and check it again.
I then fill it to the safe level, put it in gear both forward and reverse. I like to have the tires off the ground so the wheels spin and run it thru the forward gears.
I then check it again and top off before taking it for a spin.
Dave - - - -
Old Nov 20, 2018 | 08:09 PM
1981 F100's Avatar
1981 F100
Thanks for the info! With the wheels off the ground, just let the engine turn them, without touching the gas?
Old Nov 21, 2018 | 06:26 AM
FuzzFace2's Avatar
FuzzFace2
Yep you want the fluid to work thru out the trany.
Once you have the level safe you and before dropping it on th e wheels may want to run it tjru the gears giving it gas and check level again.
Dave - - - -
brooklyn
20
Nov 10, 2019 11:29 PM
Corallis
Apr 30, 2015 02:40 PM
dan8052
Aug 16, 2013 01:23 PM
BrianA
Mar 13, 2006 01:02 PM
Jason4787
Dec 25, 2003 11:42 PM
