Water Separator Keeps filling with Diesel
Installed a titan tank 2 weeks ago.
Emptied my water separator yesterday, and 1/3 GALLON of something came out. I'm not sure, but it seems like it's diesel.
Went to empty it today, and lots is coming out. I didn't let it finish. What could possibly be wrong? Of course i'm headed off to a big trip from Wisconsin to Texas next weekend, so if it's something major, I'm in big trouble.\
After I emptied it, I think I heard it filling when I ran the truck afterward.
I'm pretty sure we connected everything correctly, there were 3 of us and we went very slow.
Please Help!
Please Help!
This is all new to me, so forgive my ignorance. I read other threads where people just got a few drops out of their water separator. You're saying it's normal to fill up when the truck is run?
I feel like an idiot now.
You can’t drain the separator until the fuel tank is empty or it would make it damn hard to change that filter. When you drain the separator, let about 8oz come out and let it flow into a glass jar. That way you can see if there is water in your diesel. The water separator just helps separate the water from the fuel and let’s the diesel flow through. You have to drain the separator completely to change that fuel filter. If I remember correctly, it’s about 1/2 gallon capacity. It might be more but don’t worry, you can’t drain your tank.
You will hear it fill up when you turn the key to the on position because the fuel system is priming itself. That separator is always full of diesel. If water is the only fluid pouring out of that fitting, you have bigger problems. Lol
Received 6,667 Likes
on
You should _always_ be able to get at least a quart of fluid out of the water separator. If you're getting good fuel then it will be 100% diesel. If there is any water in the separator then it will come out first and you'll be able to tell the difference. I use a clear glass jar so I can see exactly what's in there. The opaque milk bottle may not let you see that there is a bit of water in the jug.
I'll happily take the *idiot* of the year award, or any title for that matter! I was freaking out thinking something was wrong. Like I said, I saw posts saying they only got a tiny bit of water out. I didn't realize diesel would come out too. So much for being called a separator! LOL!
Thanks for all the help everyone. It's all good now, and I also changed my fuel filters.
Hopefully this post will help someone else down the road.
As stated above, this is normal. The purpose of the separator is to keep water from being pumped into your engine, which would damage the engine. We want the separator to be full of diesel.
The purpose of draining it is to see if any water has collected in it.
I posted some additional information on the separator in this thread. Some have found it helpful also...
https://www.ford-trucks.com/forums/1...l#post17618113
The idea of draining the water separator is to ensure that you don't have any water in there with your diesel. There will always be diesel in there. Don't sweat the noobish questions, we've all been there.
Here's my methodology:
- About once a month drain about 1/2 a liter into the carafe.
- I'll set the carafe aside, to settle, until the next time I want to drain the separator
- I'll then dump that into an oil catch basin, which I'll eventually empty at my local hazmat drop-off facility
I have never been afraid to ask questions about things I have yet to gain a good understanding of. You are not the only one on this forum that wants to learn more about the separator.
I am sure there are many things I could learn from you. Well done.
