Driver window not working
Old Mar 30, 2020 | 07:13 PM
kaw1000r's Avatar
kaw1000r
Happened in the winter and I just thought it was ice or frozen. It's back not moving again I hear window click when I push button for down and up but doesn't move at all. I was thinking motor/regulator any thoughts suggestions. t/u
Old Mar 30, 2020 | 10:46 PM
shorod's Avatar
shorod
What model year is your Explorer? If you're definitely hearing the window click, versus just the switch or a relay, then the issue is probably not the rather typical broken wire between the door and cab. You best bet in the case the issue is not electrical in nature would be to remove the door panel and perform an inspection to see what's binding or not working correctly.
-Rod
Old Mar 31, 2020 | 08:38 AM
kaw1000r's Avatar
kaw1000r
-Rod
Yes it happened in the winter but when i came out for work it was working again, now a couple months later it happened again. You can like here it engage to go down or up but nothing happens. It's the same truck i just put power seats in and was asking about the gr/gy wire with silver wire in it that i am not sure what to connect it with.
Old Mar 31, 2020 | 08:45 AM
kaw1000r's Avatar
kaw1000r
Well since i am working from home i went out started it up and the window is working. It did seem to move a little slow at first coming out of weather striping. Could it be due not driving it in a few days and i do have the vent visors that are inside the door making it a little tighter?
Old Mar 31, 2020 | 08:59 PM
kaw1000r's Avatar
kaw1000r
Replaced motor/regulator and the front hole is off the back bracket isn't bent in for the foam part. Going to try to use metal part off of old regulator that connects to window. This is a supposed Dorman part...
Old Apr 5, 2020 | 12:49 PM
billybe4od's Avatar
billybe4od
04 explorer same window problem i figured that the problem is the window just jambs up too tigh against the top of door so now i close the window an just tap the botton down just a light tap enough to lower the window a bit it seem to be a winter problem here in fl so far 3 months no problem wire were all checked i was ready to buy a replacement the last time, an i was tapping the window motor with a hammer in the door then it started working so thats a my theroy !!! an i m still in the testing stage
Old Apr 8, 2020 | 12:15 PM
kaw1000r's Avatar
kaw1000r
New installed
Went with new and working great
Fffran
Oct 26, 2019 12:38 PM
bronco6767
Apr 15, 2016 10:20 PM
woody_f250
Sep 1, 2005 10:04 PM
fordtrkpuller
Mar 7, 2005 09:35 PM
