Battery ground cable location
Old Mar 29, 2020 | 09:07 PM
Rsmach1's Avatar
Rsmach1
Hello, can anyone tell me where the negative battery cable originally terminated on a 74 F100? I've always thought it went straight to the engine block and the chassis was grounded off a wire from there, as well as the cab having a ground off the engine itself. Am I wrong?
Thanks.
Old Mar 29, 2020 | 09:09 PM
440 sixpack's Avatar
440 sixpack
You're correct.
Old Mar 29, 2020 | 09:12 PM
Rsmach1's Avatar
Rsmach1
I thought so, a friend said his came off the apron or chassis and then to the block.
Old Mar 29, 2020 | 09:15 PM
440 sixpack
Never from the factory. . the starter is the heaviest draw in the system it has to have a solid ground.
Old Mar 29, 2020 | 09:22 PM
Rsmach1's Avatar
Rsmach1
That was my argument as well, Thank you sir.
Old Mar 29, 2020 | 09:30 PM
Tedster9's Avatar
Tedster9
Maybe not by '74, Ford did cheap out in prior years to that though and ran the negative cable directly to the firewall, behind the battery, and another from the firewall to the engine block. All of the OEM beancounters not just Ford seemed to treat copper as a semi-precious metal and always used fairly light gauge cable as short as possible.
Old Mar 29, 2020 | 09:36 PM
Rsmach1's Avatar
Rsmach1
Seem to remember my 72 F250 (years ago) ran to the engine mount and from there a short cable to the cross member, as well as a thin ground strap from the rear of the engine to the cab. But I'm getting old and have forgot a percentage of what I know 😂
Old Mar 29, 2020 | 09:48 PM
440 sixpack
I've seen that a few times on older rigs. but essentially the ground cable just makes a stop on it's way to the block. it still isn't grounding off the cab as an accessory it is the main ground to carry the amps. .
I
Old Mar 29, 2020 | 11:11 PM
Tedster9's Avatar
Tedster9
Well sure, but when they save money on copper, now there's 2 extra connections there, where ideally there would only be that one. The one thing about electrical connections, high current low voltage, or any electrical connection really, they are always a potential point of failure, they start to degrade on day 1 and will eventually fail altogether, it's just a matter of time. Most people are familiar with battery terminal failure but it's the same problem at any terminal.
The road salt spray and pollution accelerates this big time. I always buy a big *** cable and run it direct to the block or a bolt on the starter. Block, frame, firewall.
Old Apr 1, 2020 | 02:49 PM
four-sixty-power's Avatar
four-sixty-power
Electrical problems? Check your grounds, clean your grounds, replace the grounds!
Old Apr 1, 2020 | 03:17 PM
Rsmach1's Avatar
Rsmach1
No problems, was just looking for confirmation on the original location. But ty
High_HP
Oct 30, 2018 06:01 PM
tombob
1978 - 1996 Big Bronco
Nov 12, 2007 01:39 PM
pdqford
Jul 15, 2004 01:14 PM
rlp
Electrical Systems/Wiring
Jun 1, 2004 12:29 PM
slntnddly
Dec 22, 2003 06:40 PM
