Trying to find proper UJoints
Old Mar 28, 2020 | 04:56 PM
joe4law's Avatar
joe4law
1982 F 250 4wd 400 motor. Both U joints need replacing. Driveshaft from transfer case to rear end. Removed driveshaft and bad u joints. Ordered u joints from Summit. Don't fit. Ordered from Rock, don't fit. Need to find u joints. Any suggestions?
Old Mar 28, 2020 | 08:15 PM
matthewq4b's Avatar
matthewq4b
Whit size U joints do you have ? 1310 or 1330 series ? Ford used an oddball 1310BC and 1330BC on many applications.
How about linking us the joints you bought and telling us how they did not fit..
Old Mar 29, 2020 | 05:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
A/T or M/T? Regular, Super or Crew Cab?
Old Mar 29, 2020 | 08:12 AM
joe4law's Avatar
joe4law
M/T Regular cab.
Old Mar 29, 2020 | 08:13 AM
joe4law's Avatar
joe4law
OK. I'll wait till daylight and get that info.
Old Mar 29, 2020 | 08:24 AM
FuzzFace2's Avatar
FuzzFace2
Also need to know if inside or outside retainers for the caps.
A lot of information given is for measurements across both shafts, the cap dia. and as I posted in or out retainers to get the right size.
So why don't you go local for them?
If they don't fit then you can retune them pretty easy and try and find the right ones.
Dave ----
Old Mar 29, 2020 | 08:53 AM
joe4law's Avatar
joe4law
Don't know about series. On the original U joint it has: 9A F279 on one side. The other side has; A6 52
One I got from one company is not symmetrical like mine. Mine is 3 7/8 from cup to cup on both sides. The "replacement" is 3 5/8" on one side cup to cup and 3 1/4" on the other.
The other one I got has inside clips on 2 cups and outside clips on the other 2.
Both my u joints on the driveshaft, front and back, have U bolts and outside clips.
Wait a minute. The one with the inside clips have the same measurements as my old u joint. The only difference is in the inside clips on the new one. That shouldn't matter if I
they go into the holes in the driveshaft. Should it?
Old Mar 29, 2020 | 08:55 AM
Franklin2's Avatar
Franklin2
Look where the joint goes. If it's not machined flat on the inside, but instead is a rough forging from the factory, then the inside clips will not work.
Old Mar 29, 2020 | 10:21 AM
NumberDummy
1982 F250 4WD 400 M/T Regular Cab.
C3AZ-4635-M .. Front/Rear U-Joint #1330 - Spicer/Cleveland steel type with inside clips // All 4 cups are 1 1/8" diameter // Should be available from any auto parts store.
Used in myriad 1950's/21st century FoMoCo vehicles.
Old Mar 29, 2020 | 03:27 PM
matthewq4b's Avatar
matthewq4b
Bill nailed it ,
This the spicer 5-1204X.
Spcier is the OEM for Ford
scsprop
Sep 18, 2014 09:22 PM
limptera13
Jul 28, 2010 07:59 PM
MacPhly
Nov 30, 2007 02:33 PM
f-250.4x4.390
General Automotive Discussion
Sep 27, 2005 06:09 PM
mrshorty
Bronco II
Jul 2, 2002 08:01 PM
