Door push button keypad
Old Mar 28, 2020 | 11:52 AM
RetiredMarine's Avatar
RetiredMarine
Hello everyone. When I bought my 06 f250 I wasn't given the code for the keypad on the door. Does anyone know if there is a way for me to find out what it is?
Old Mar 28, 2020 | 12:06 PM
seville009's Avatar
seville009
Here’s one of many threads
https://www.ford-trucks.com/forums/1...-location.html
Old Mar 28, 2020 | 01:53 PM
xcrsp440's Avatar
xcrsp440
It seems there are several differing locations for this elusive code. On our 2004 I had to lay on the floor, head by the throttle pedal looking up above the hump moved insulation and found the elusive box. But the code was on the sticker facing away from view. I snaked my arm up and around and using my phone after several attempts, took a picture.
good luck.
Old Mar 28, 2020 | 05:12 PM
87crewdually's Avatar
87crewdually
To add, you can also retrieve the factory set code using Forscan, if by chance you have that already for diagnostics.
Old Mar 29, 2020 | 02:40 PM
Restlesswildman's Avatar
Restlesswildman
You might want to post a location. Someone close to you might have the tools to plug in and get it for you.
Old Mar 29, 2020 | 09:23 PM
AK4x4's Avatar
AK4x4
This is so obvious it's silly, but did you check the owners manual in the glove box (assuming there is one) for the credit card size piece of plastic with the code on it? Russ
Old Mar 29, 2020 | 09:39 PM
RoberDen's Avatar
RoberDen
I have used ForScan several times (2005 EX), have never seen that option. Could you elaborate please. Thanks.
Old Mar 30, 2020 | 03:24 AM
bismic's Avatar
bismic
Do you have it on a laptop or on a phone app?
Old Mar 30, 2020 | 04:24 AM
RoberDen's Avatar
RoberDen
Laptop with the extended (paid) version.
Old Mar 30, 2020 | 03:16 PM
Yahiko's Avatar
Yahiko
That only works if the previous owner didn’t throw the card out.
Old Mar 31, 2020 | 09:25 AM
RetiredMarine
I have looked and it is not there. I will find it tomorrow because today I am going to go see my daughters new land they bought to build the new house on.
Old Mar 31, 2020 | 10:39 AM
RoberDen's Avatar
RoberDen
I have seen posts where it was said there is a paper label behind the radio on the firewall that has the code. I tried looking for it on mine and could not find it, even pulled the radio forward. No dice.
Old Mar 31, 2020 | 11:35 AM
87crewdually
I've retrieved them on trucks using the Lite version. Here's a screen shot.
​​​​​​ . I just went out and tried it on my 05 and don't see the Keycode PIDs anymore. Maybe it was on a newer Ford.
I blurred out a few digits even though it isn't from my truck.
But this is what the readout would (use too) look like.
KingKorn
Mar 24, 2011 12:05 AM
adbscu
Apr 25, 2009 11:26 PM
heshmastr
Mar 6, 2003 06:48 PM
