Intake help
Old Mar 27, 2020 | 09:02 PM
Branden Heine's Avatar
Branden Heine
Intake help
I’m undertaking the task of replacing my intake gaskets and I have some questions
1 what Is the rocker assembly torque spec and what’s the proper way to remove them?
2 what’s the torque spec for the intake and what sequence do I follow to remove the bolts?
3 how should I put the gaskets on the intake?
4 last question if I’m that far in should I go ahead and replace my head gaskets?
Old Mar 27, 2020 | 10:35 PM
RichS2659's Avatar
RichS2659
Since you are starting out, pick up a copy of the Haynes manual for 73-79's since it will help tremendously, and it is cheap. They are pretty much the same for the most part.
Old Mar 27, 2020 | 11:07 PM
resonateur's Avatar
resonateur
I would only approach the head gaskets if there is a good reason to do so. Do you have reason to believe that they’re blown??
Old Mar 27, 2020 | 11:45 PM
Branden Heine
no but they are the original ones and have 150,000 miles on them
Old Mar 28, 2020 | 01:06 AM
resonateur's Avatar
resonateur
....so does everything else that wears such as bearings, valves and rings. Maybe consider a full rebuild...otherwise I don’t know what advantage head gaskets alone would provide.
AbandonedBronco
Apr 23, 2017 06:08 PM
marilyn
Mar 3, 2006 06:01 PM
MustangGT221
Mar 17, 2005 09:19 AM
afinepoint
Jan 2, 2004 11:31 PM
Katt
May 20, 2000 05:14 PM
