CAC Pipe Woes
Old Mar 27, 2020 | 01:18 PM
mjs2011's Avatar
mjs2011
Originally Posted by Overkill2
They can be a pain to install but my kit is still on and working. Larry wrote a great install thread here:
https://www.ford-trucks.com/forums/1...t-install.html
They now have kits that are one solid silicone pipe from the CAC right to the throttle body adapter. More expensive but JMO, worth it. If I ever have an issue with mine, this will go in the Rudy's place:
https://spediesel.com/products/spe-6...cold-side-pipe
I think if I did it again, I'd probably give a one piece silicone kit a try. I like the idea of them. Simpler with fewer connections.
Originally Posted by dirthawg
It's good to see the price has become more reasonable. The OEM part at one time was over $200, actually closer to $250 if I remember correctly. Everyone switched to aftermarket which was cheaper at the time and much better built.
Worth noting that AutoNation Ford prices are extremely low. I buy nearly all my OEM Ford parts form them, as their prices are usually the lowest you can find. I'd reckon the same OEM cold side tube from the stealership would be well over $100 bucks for the same part. If I recall correctly, the OEM cold tube that I bought is supposed to be the upgraded ford kit as well. I believe it was intended to remedy some of the rupturing concerns that they had, but I can't say that for certain, and I've yet to install it. Its still in the box just waited to be put into service.
Old Mar 27, 2020 | 04:04 PM
PROSTOCK's Avatar
PROSTOCK
30 minutes ago. Daughter driving back from A&M
Old Mar 27, 2020 | 05:44 PM
senix's Avatar
senix
Still running the original for me. I have an oem spare just in case.
Old Mar 27, 2020 | 07:12 PM
PROSTOCK's Avatar
PROSTOCK
Called dealer in town and they had 1 for $107 out the door, not bad, would have been $85 via interwebs. Is there a write up for a factory pipe R&R? Doesn't look too hard, but it's always best to be armed when tackling a new job. This will be the first wrench I've lifted for this truck other than shocks.
Old Mar 27, 2020 | 07:25 PM
dirthawg's Avatar
dirthawg
No write up needed. A flat head screw driver to pop the spring clip on the throttle body and a 10mm deep socket for the clamp on the intercooler is all you need. Twist the sensor out and replace it in the new pipe and your back on the road.
Old Mar 27, 2020 | 07:39 PM
PROSTOCK's Avatar
PROSTOCK
Thanks, it looks simple, but you never know. No need to change the sensor, the pipe has one pre-installed. Going to change it in the AM.
Old Mar 27, 2020 | 07:42 PM
Just Strokin's Avatar
Just Strokin
You might need a long 1/4" drive extension for the deep well 10mm socket to loosen the lower clamp on the inter cooler. Also, you might want to relocate the power steering reservoir out of the way for better access.
Old Mar 28, 2020 | 07:19 AM
Overkill2's Avatar
Overkill2
How many miles on your 12?
Old Mar 28, 2020 | 11:12 AM
Overkill2's Avatar
Overkill2
Originally Posted by mjs2011
I think if I did it again, I'd probably give a one piece silicone kit a try. I like the idea of them. Simpler with fewer connections. Worth noting that AutoNation Ford prices are extremely low. I buy nearly all my OEM Ford parts form them, as their prices are usually the lowest you can find. I'd reckon the same OEM cold side tube from the stealership would be well over $100 bucks for the same part. If I recall correctly, the OEM cold tube that I bought is supposed to be the upgraded ford kit as well. I believe it was intended to remedy some of the rupturing concerns that they had, but I can't say that for certain, and I've yet to install it. Its still in the box just waited to be put into service.
Agreed about the less connections POV.
I use https://www.villagefordparts.com/
Old Mar 28, 2020 | 07:20 PM
The Bone's Avatar
The Bone
Here is the thing that made me change my CAC pipe. I had the rubber hose come lose under the SS band that is welded. How on earth could that happen? I wasn't even towing or pushing the truck. Next morning I went to Ford and got a proper hose clamp $50 and fixed the hose. Then I decided with all the problems people are having why take the chance? So I replaced mine with one from Rudy's.
Here's the thing, If your truck brakes it won't be in your driveway. If you don't mind fixing or replacing your CAC pipe on the side of the road than don't replace the stock. If you don't than fix it in your driveway.
You can thank me later.
Old Mar 29, 2020 | 08:11 AM
Overkill2's Avatar
Overkill2
Rudy's offers their kit in black on their website.
https://rudysdiesel.com/i-30508577-r...werstroke.html
Old Mar 30, 2020 | 03:57 PM
PROSTOCK's Avatar
PROSTOCK
The truck has just under 70K on it. The R&R took 7 minutes, yes I timed it, and that includes getting the right size socket, which is not 10mm, it is 7/16". 7/16" deep socket with a 12" extension and a long screwdriver that pops the clip and also helps pry the hose off the inter-cooler. It took much longer to get the black crap off my hands. A little of that goes a looong way.
Incidentally the diesel tech at the dealer said they have never replaced a replacement.
Old Mar 30, 2020 | 07:15 PM
  #28
dirthawg's Avatar
dirthawg
Sorry to steer you in the wrong direction on the 10mm deep socket. If you would have installed an aftermarket kit you could have used that 10mm socket!
What the hell was Ford thinking....we can take the rest of the truck apart with a 10mm socket but we have to dig for an SAE socket to get the intercooler pipe off?
Old Mar 30, 2020 | 07:37 PM
  #29
Overkill2's Avatar
Overkill2
Good luck with the replacement. But I'm a believer in Mr. Murphy...at least for me anyways.
Old Apr 1, 2020 | 12:22 PM
  #30
wizardsr's Avatar
wizardsr
Thanks all for the feedback! I ordered the Rudy's kit with both hot and cold side pipes, I figured for a $40 difference to do the hot side too, why not... Be glad to have the leaky H&S overpriced silicone pile of crap off my truck!
