1982 E350 no power,no start condition
Old Mar 21, 2020 | 07:55 PM
1979_Red_Ford_Truck's Avatar
1979_Red_Ford_Truck
Went to start up my newly acquired 1982 E350 and it won't start. I turned on the headlights, they do not come on. Dome light not coming on as well. No power at all. I installed the new starter that came with it, and the battery I bought for it is good, had it tested . It seems like it is not getting power somewhere, what / where should I be checking? I was thinking a missing ground wire, but don't know where they should be on the Econoline. I did notice an orange fusible link near the cowl, that had a "bump" in the insulation, (see attached photo) Could that be the culprit?
Old Mar 22, 2020 | 10:40 PM
Spaznaut's Avatar
Spaznaut
the ground will be right at the battery to the body. Then one will go down and attach to the body and frame. The bracket that attaches to these is a grounding point. Check it for corrosion. Also make sure the battery is getting a good connection. I'd check the wires at the battery first since even though they look okay the connection may be crap from corrosion on the cables especially the crimp style clamps. If nothing else get new wires. A decent meter and a friend to turn the key while you check voltage at the battery and then wires and working your way down the connections will be your best bet.
Old Mar 23, 2020 | 07:12 PM
1979_Red_Ford_Truck
Okay a little update: I swapped starter relays, still no headlights/dome lights and nothing when I use the key. BUT I can now jump across the relay posts and get it to crank over. Also observed no ground wire running from the neg terminal to body and none from the engine to the frame rail
bigbrown1985
Dec 28, 2012 11:17 AM
Joeseph
Nov 23, 2011 07:14 PM
supercab blue
Mar 5, 2007 09:35 AM
jimbo96
Jun 3, 2004 08:15 PM
Kevin_
Feb 21, 2002 05:27 PM
