idi no start
Old Dec 26, 2012 | 01:53 PM
bigbrown1985's Avatar
bigbrown1985
idi no start
the truck ran fine last night did a little mudding shut it off and it started back up go out this mornig and it wont start batteries are fine when the ign is off i have power to the cigarett lighter but as soon as i turn it to the on position no power what so ever
Old Dec 26, 2012 | 03:39 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Bad connection at the battery or on the other ends of the cables?
Otherwise the batterys may not have enough charge.. headlights bright?
Old Dec 26, 2012 | 03:41 PM
bashby's Avatar
bashby
Probably a bad connection at a battery terminal, engine ground, or most likely at the starter solenoid. If you don't have a voltmeter or test light start with cleaning them.
Old Dec 27, 2012 | 08:16 PM
bigbrown1985
it decided to start today after doing nothing to it
Old Dec 28, 2012 | 07:58 AM
bashby's Avatar
bashby
I'd go ahead and clean the connections I mentioned above. You know it will do it again at the worst possible time. You might also want to carry a voltmeter or test light with you in case it does it again.
Old Dec 28, 2012 | 11:17 AM
TheKirbyMan's Avatar
TheKirbyMan
Check the connections at the battery, if it goes dead like that it's usually a poor connection there. It'll run the lights and lighter socket since they're low power but when you start trying to pull hundreds of amps...
Codyaye
Feb 15, 2016 10:03 PM
jprankin
22
Nov 18, 2014 06:53 AM
Yukon
May 7, 2014 10:51 AM
truckbeast
Nov 7, 2012 08:12 AM
jimbo96
Jun 3, 2004 08:15 PM
