Sponsored by: Real Truck
FORScan TPMS Threshold
Old Mar 17, 2020 | 10:38 AM
PancakeF150's Avatar
PancakeF150
I sware I have done a search and did not find exactly what I am looking for. I have a 2014 F350 Lariet I need to lower the TPMS threshold to 65. I have FORScan and have set a few things. When I find anything about setting my TPMS to a lower limit there is a mention of Hex, something or other. Can someone give me the FORScan line and the Hex value I need to set my bottom limit to 65?
Thank you in advance
Terry
Old Mar 17, 2020 | 04:07 PM
Just Strokin's Avatar
Just Strokin
Check this spreadsheet for the values you are seeking. The title says 2016 but the 2014 is the same.
FORScan 2016 Super Duty - Google Sheets
Old Mar 17, 2020 | 06:13 PM
PancakeF150
Thank you, Larry.
I'm having trouble converting to the hex
"TPMS Enabled AB=Front Tire pressure converted to hex, CD=Rear Tire pressure converted to hex"
Old Mar 17, 2020 | 06:31 PM
Just Strokin
you can use this convertor to get the hex to decimal....
https://www.thecalculatorsite.com/ma...to-decimal.php
or decimal to hex
https://www.thecalculatorsite.com/ma...mal-to-hex.php
Old Mar 17, 2020 | 06:50 PM
PancakeF150
Thank you Larry!!
I appreciate it very much..
Old Nov 5, 2021 | 11:10 AM
1Legacy's Avatar
1Legacy
or decimal to hex
I dont know why this is so confusing for me but what number would I input into the forscan if I wanted my TPMS set to 50 psi?
Old Nov 5, 2021 | 02:13 PM
ifrythings's Avatar
ifrythings
32 hex equals 50 decimal, so in the “TPMS Enabled” AB = 32 and CD = 32 would set your tire pressure to 50psi front and rear.
Old Nov 10, 2021 | 08:24 PM
2001F250_7.3's Avatar
2001F250_7.3
Do you know where I can get those spreadsheets for a 2001 F250 7.3L?
Old Nov 11, 2021 | 05:01 AM
projectSHO89's Avatar
projectSHO89
Those types of changes were not possible on that old of trucks.
Old Nov 17, 2021 | 03:35 PM
PatrickStapler's Avatar
PatrickStapler
Is this why I keep getting a TPMS warning indictor? I have them tested...they test good. I replaced them...they test good. Keep getting the warning. Is a FORScan required to lower this threshold?
Will Gilbert
Apr 6, 2016 08:08 AM
dthut
Apr 3, 2016 01:16 PM
1978fordshort
Dec 8, 2013 10:46 AM
Surge08
Pennsylvania Chapter
Oct 14, 2008 08:41 PM
