Rear Window Gasket
Old Mar 16, 2020 | 09:37 AM
BassFantasizer's Avatar
BassFantasizer
Rear Window Gasket
I need to replace the rear window gasket in my 2000 Ex. The original (now 20 year old) gasket is hard and doesn't flex at all.
Rockauto has a Fairchild gasket on their site for $20. Was looking for opinions on it, or anything else that's out there.
Thanks!
~Bass
Old Mar 16, 2020 | 10:07 AM
RazorsEDGE's Avatar
RazorsEDGE
Just to be clear which rear window are you talking about exactly? Rear door? Rear quarter? Rear hatch?
Old Mar 16, 2020 | 12:15 PM
BassFantasizer
Rear hatch. It would never occur to me to call side windows "rear".
Old Mar 16, 2020 | 04:51 PM
01__Excursion's Avatar
01__Excursion
You probably already know that the gasket is the full body gasket that seals the lift-gate, and barn doors where they meet the body.
Somehow $20.00 doesn't sound correct.
FYI: that rear body gasket is glued to the body with some very sticky stuff, it will allow you to pull the old gasket away, I advise leaving what's left behind on the body and allow it to make contact with the new gasket.
Here is the Ford part number.
Old Mar 16, 2020 | 08:52 PM
SmackDaddy's Avatar
SmackDaddy
Nicmike has a write up on how he resealed his. I have the supplies just haven’t gotten to it yet. Search his posts, dude is detailed.
Old Mar 18, 2020 | 01:03 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
My write up is for the glass itself and the butyl rubber tape that seals the glass to the hatch around the 16 nuts and studs.
Which one you need, Bass?
Old Mar 18, 2020 | 01:18 PM
BassFantasizer
The gasket on the bottom of the lift gate. It's hardened to where it has the texture of schedule 40 PVC and scraping the paint off the tops of the barn doors.
Old Mar 18, 2020 | 01:21 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Ah, I had that same problem. I just removed it.
Old Mar 18, 2020 | 07:08 PM
01__Excursion
Ahh, mine is doing the same thing.
fetusgrinder
Ford Truck Parts for Sale
Apr 15, 2017 12:06 AM
jgavac
Jan 1, 2017 09:33 PM
jconis
Aug 18, 2015 04:26 PM
9d4
Feb 1, 2010 01:22 PM
