At a loss
Old Mar 15, 2020 | 08:20 PM
F1sheety's Avatar
F1sheety
At a loss
I’m lost, I have a 86 f150 that has a problem with battery not charging I believe. I have a new alternator, battery, starting solenoid new ground wire. The truck won’t start unless jumped. Once jumped it will fun fine for until I turn it off. Once I turn it off it will not start unless jumped. I can remove my positive terminal and the truck will continue to run. I am at a loss
Old Mar 15, 2020 | 08:38 PM
FuzzFace2's Avatar
FuzzFace2
Welcome to FTE.
First never remove any battery cable when the motor that is a good way to make stuff go bad.
Fully charge the battery before we start looking into what could be going on.
Tell us what you get for volts across the battery with your meter.
When you say "jumped" how are you doing this step by step.
Then we can see what we can find wrong.
BTW is the truck an auto or stick transmission?
Dave ----
Old Mar 15, 2020 | 08:47 PM
Kramercd's Avatar
Kramercd
Be sure and clean your battery terminals and cable ends while you are at it.
Old Mar 15, 2020 | 08:57 PM
F1sheety's Avatar
F1sheety
Welcome to FTE.
Dave ----
I apologize if I’m not replying the Wright way I’m new to this site. Anyway, thanks for letting me know about removing the terminal while running I was told bad info. For jumping it I hooked it to a running vehicle and waited a few minutes and it started. I just tired to start it after I had been running for about 30 minutes and it wouldn’t start. I tested it with my meter and it’s saying the battery has 12.50 but when I turn the key I get nothing.
Old Mar 15, 2020 | 09:00 PM
F1sheety's Avatar
F1sheety
So I bypassed the starting starting solenoid and the truck started. This is the 3rd one I have put in this month what would cause it to fail?
Old Mar 15, 2020 | 09:18 PM
FuzzFace2's Avatar
FuzzFace2
You posted ok we will not be kicking you off just yet
So the jumpers go from the other cars battery to your trucks battery and it then starts?
You say you jumped the solenoid how was this done?
Do you get any lights on the dash to come on when the key is turned on?
At first I am thinking bad battery connection.
It would not hurt to clean the connections at the battery and the other ends of the cables.
Or if they have some age on them just replace them as you can not tell if they are bad till you cut them open.
Dave ----
82_F100_300Six's Avatar
82_F100_300Six
what is the voltage reading when it is running?
Old Mar 15, 2020 | 09:22 PM
Kramercd's Avatar
Kramercd
So, it was a common troubleshooting procedure to remove the positive cable to test the alternator. But that was on pre computer vehicles. The voltage spike can cause damage to sensitive electronics, such as the computers that run vehicles these days. Now when you say bypassed the starter relay, how did you do this? Did you jump the big leads? What about if you jump the ignition terminal on the solenoid to the battery side of the solenoid? You may not be getting power on the start wire from the ignition. But that doesn't fit with you can only start it if you jump it. That would point to a weak battery or bad connections.
Old Mar 15, 2020 | 10:27 PM
kr98664's Avatar
kr98664
Lots going on here. Lots of good advice, but unfortunately it's all over the place as where to begin troubleshooting. Here's what I recommend:
Charge your battery. This is from Electrical Troubleshooting 101. Don't count on the alternator or a jump start. You'll want a charger with at least a ten amp output, preferably automatic. A trickle charger won't cut it. Hook up the charger overnight.
The next step is to test the control circuit to the starter relay. This is a good place to begin troubleshooting, as this test breaks the entire starter system in half to isolate the fault.
Disconnect the wire from the small S terminal on the starter relay. Connect your meter to check for voltage at the disconnected wire. Key off should be no voltage. Key to run, still no voltage. Turn the key to start and you should now see voltage. Release the key back to run and the voltage should return to zero.
If that tested good, the control circuit to the starter relay is good.
Next step is to put the transmission in neutral (or park if auto) and set the parking brake. Ignition switch to off and remove the key. Stay clear of the drive belts and fan blades as the starter should engage for the next step. Momentarily connect a small test jumper from the battery (+) terminal to the small S terminal on the starter relay (original wire still disconnected). The starter relay should make a big clunk and the starter should engage. This test lead mimics the normal control command from the ignition switch.
Five minutes tops. Try those two quick tests and report back.
Adrian Arnold
Sep 18, 2018 02:55 PM
benjamin1992
May 6, 2017 06:00 AM
Killian88
1997 - 2003 F150
Jan 15, 2011 07:23 AM
specialist484
Jun 30, 2007 02:12 PM
sirrockspr
Aug 15, 2004 12:54 PM
