Truck won't start!
Old Aug 19, 2018 | 10:28 AM
Adrian Arnold's Avatar
Adrian Arnold
Truck won't start!
1994 F150 Stright 6
took alternator off. Got it tested it passed
got new battery.
now it just clicks and started won't engage
hellp!
Old Aug 19, 2018 | 10:47 AM
byronbgs's Avatar
byronbgs
Get the starter checked out. Check for corrosion at the connection where the wire is clamped by the battery terminal.
Old Aug 19, 2018 | 10:55 AM
Adrian Arnold
The battery terminals are fine.
Old Aug 19, 2018 | 11:10 AM
90paul250's Avatar
90paul250
stick a screwdriver between the terminals on the solenoid....if it starts then get a new solenoid...
Old Sep 18, 2018 | 01:10 PM
Adrian Arnold
Something to do with distributer. Had him crank it and then turned the dist. And then started
Old Sep 18, 2018 | 02:55 PM
sandymane's Avatar
sandymane
If the distributor turned by hand without loosing the hold down bolt, you need to remove the spout and set the timing to 10* BTC and then replace the spout and tighten the hold down bolt so the distributor won't turn. If it is running good you may have it close but I wouldn't rely on that. The hold down bolt is a pain to get to because it is somewhat recessed. They make a tool for doing it or you can bend an old box end wrench to compensate. Sandy
truckbeast
Nov 7, 2012 08:12 AM
mgomez
May 10, 2010 01:07 PM
74scamp
Jan 4, 2010 09:50 PM
RedInline6
Jan 27, 2004 11:53 AM
LilCop2002
1997 - 2003 F150
May 18, 2003 07:32 PM
