Low Oil Pressure Warning
Old Mar 14, 2020 | 07:10 PM
happylogan1's Avatar
happylogan1
Today I kept truck running to load up some mulch. Put in drive-go to leave and truck’s low oil pressure warning came on. I turned off truck. Restarted and it ran sluggish for .5 mile then “ran normal”.
Oil pan/ gasket replaced 2 weeks ago. They put in standard grade oil. Previously running full syn. Some research says oil sending unit may not be the fix. Could this be a software/ computer issue?
I did not notice, was not looking, at the oil pressure guage on dash. Went on to finish the 20 mile drive in stop and go traffic. Ran fine. I am considering changing to a higher viscosity full synthethic?
Old Mar 14, 2020 | 11:07 PM
Lime1GT's Avatar
Lime1GT
Was the rpm too low when you pulled away? Maybe you should have a mechanical oil gauge connected to see if your oil pressure is too low. Conventional oil is fine to run in these vehicles. They just need to be changed at a lower mileage than synthetics. I don't use synthetics in either my 02 F-150 5.4l or my 17 Mustang GT 5.0l and haven't had any issues. Truck is my winter/summer driver and the Mustang is just summer due to summer tires on it.
Old Mar 15, 2020 | 11:30 AM
gDMJoe's Avatar
gDMJoe
Lightbulb
Obvious question - Have you checked the oil level after the oil change?
Old Mar 15, 2020 | 01:48 PM
happylogan1
Yes, oil new and correct amount.
Old Mar 15, 2020 | 08:07 PM
Sportscape's Avatar
Sportscape
My first thought is did they use a cheap filter? the second thing is how well did they clean things up, could the mechanic have scraped gasket and sealer and left crud in the oil pan?
Old Mar 15, 2020 | 08:30 PM
happylogan1
I paid dealership fees for this oil pan gasket repair so I guess it’s oem parts. But, anything can happen. Today, it did not flash the low oil warning
Old Mar 17, 2020 | 11:07 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I suspect the oil pressure sender.
Get something that can read the PCM's telemetry, watch the oil pressure from before start. Start the engine, let it settle, rev it a couple of times. If the pressure acts as it should (zero before start, run up at start, slight changes with revving) then you're getting some kind of reading and it's probably not a PCM issue. Now the question is: What oil pressures did you see? Were they close to minimums?
Rpayne
Mar 16, 2010 03:58 PM
Doxy
1997 - 2003 F150
Jun 7, 2009 05:15 PM
thegreatwhitefarmer
18
Mar 3, 2009 04:40 PM
77fordguy
Jan 11, 2005 04:07 PM
Boss50
Mar 13, 2004 10:39 AM
