Sooty o2 sensor
Old Mar 2, 2020 | 03:19 PM
jhinalabama's Avatar
jhinalabama
Sooty o2 sensor
2011 screw 3.5 eb..Trucks got 202k on it. Got a bank 2 sensor 1 fault. Figured I would just change both #1's. One of them, bank 1 looks normal to me bank two looks sooty like i might have a problem. What do you guys think?
Old Mar 2, 2020 | 06:04 PM
Siberexpress's Avatar
Siberexpress
Sensor goes out it might be giving it to much fuel to try and compensate causing both the Plugs and O2 Sensor to carbon up. I would check the plugs on that side also, might need to be cleaned and the gap checked.
Old Mar 2, 2020 | 07:02 PM
jhinalabama
Thats not a bad idea. I was getting a gas smell in my oil to, so i changed the oil when i changed the o2 sensor thinking maybe it would clear that up too.
Old Mar 3, 2020 | 05:50 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I've had to change both of my upper sensors and went ahead and changed all four over a 12 month period. The two uppers threw a code exactly one year apart. After the second one failed, I changed the bank #2 upper and both lower units.
Old Mar 17, 2020 | 02:56 PM
spongecop's Avatar
spongecop
Semper Fi
can yall provide the part numbers you used? I got a p2098 and I think thats the downstream left side one
Old Mar 17, 2020 | 04:58 PM
bwep's Avatar
bwep
If they have 200,000 on them they have done there job. Replace as a pair.
As for the soot more likely oil. Does the engine use oil ?
Old Mar 18, 2020 | 06:52 AM
tseekins's Avatar
tseekins
Sorry, I had them done as I have a bum shoulder and had a hard time getting to the connectors.
My truck was throwing a code as the two upstream sensors failed a year apart. The sensors were covered in soot but my truck isn't using oil and there's no gasoline blow by in the oil and no gas smell.
In an earlier post it was mentioned that worn plugs could be a culprit.
Rumble phish
2004 - 2008 F150
17
Dec 20, 2018 09:09 AM
68firebirdman
Apr 4, 2018 08:31 PM
linjoye
1997 - 2003 F150
May 16, 2007 03:55 PM
GWTarpon
3.8 & 4.2L V6
Jul 12, 2004 12:53 AM
nastruk95
General Automotive Discussion
Apr 27, 2004 07:32 PM
