Starter Bendix problem
Old Mar 14, 2020 | 05:50 PM
ktm4012's Avatar
ktm4012
Hello, I have a 79 Ford F 250 with a 400 and the starter stopped working. When I pulled it out there was a small short dowel pin sitting next to the bendix gear. I can't figure out where this pin came from. I'm thinking it's about 3/16 diameter. Is there a dowel pin somewhere in the bendix assembly?
Old Mar 14, 2020 | 06:25 PM
Red Mercury's Avatar
Red Mercury
The starter drive/Bendix has several rollers in it that fit that description. I can't remember exactly but maybe 5 of them. Sometimes the rollers come out when the Bendix housing is broken. You can buy a new Bendix for a Ford starter and they are not hard to change. You used to be able to buy a kit that came with Bendix, bushings, and brushes. I am a big on rebuilding starters and alternators instead of taking a gamble with the "supposed to fit" chain store exchange units.
Old Mar 14, 2020 | 06:28 PM
72rtchallenger's Avatar
72rtchallenger
Unsure about starter but there are dowel pins on back of engine block for tranny to line up to block
Old Mar 14, 2020 | 06:31 PM
ktm4012's Avatar
ktm4012
Thanks, I have been trying to find an exploded view of a starter or bendix to see if I can find thin pin. Google has not been any help.
Old Mar 14, 2020 | 06:32 PM
ktm4012's Avatar
ktm4012
These pins are much smaller than the ones you mention.
Old Mar 15, 2020 | 06:41 PM
72rtchallenger
Is there a pin to secure the gear on shaft on end of starter ? Perhaps it sheared or fell out ?
Old Mar 16, 2020 | 03:03 PM
matthewq4b's Avatar
matthewq4b
A pic would help. But that pin or the piece of it is likely the pivot pin from the movable pole shoe. It is retained in place by the pole shoe cover. Without it the starter will not work...
See below Circled in red.
Old Mar 16, 2020 | 06:04 PM
ktm4012's Avatar
ktm4012
Well, I figured it out, it was parts inside the bendix that keep the gear spinning in one direction kind of like a clutch. Red Mercury had it right.
uknunn
Jul 4, 2018 11:57 AM
Full-Time Ford
6.7L Power Stroke Diesel
30
Sep 28, 2017 07:35 AM
john griffin
Apr 7, 2012 11:32 AM
FordFadgeole
Aug 31, 2004 02:41 PM
Chevythunder7578
Feb 6, 2004 10:59 PM
