1960 Starter Drive
Old Feb 6, 2004 | 12:36 PM
Chevythunder7578's Avatar
Chevythunder7578
Exclamation 1960 Starter Drive
I just won an ebay auction for a starter. It does not come with the starter drive so I need to re-use my old one. I am not sure how to remove my existing drive. I'm thinking i have to knock out the pin but I'm not sure. The starter is from a 1960 223 manual
Old Feb 6, 2004 | 01:52 PM
57_ford's Avatar
57_ford
Their are maney different drives. But the last one I did. I had to pull back on the warsher that has pressure on the pin at the same time drive the pin (at the very end) out just enough so that it slides off the shaft. Do not drive the pin all the way out.
Old Feb 6, 2004 | 02:56 PM
Chevythunder7578
Which way do I pull the washer? Off the shaft or towards the starter?
Old Feb 6, 2004 | 05:19 PM
57_ford's Avatar
57_ford
Towards the starter. Their may also be step made in that warsher.
Old Feb 6, 2004 | 10:59 PM
atticmole's Avatar
atticmole
I put my drive in a vise and it seemed pretty easy to get enough tention on the drive spring to get the get the pin out.
ger_man
Nov 10, 2012 07:27 AM
ger_man
Sep 30, 2012 01:22 PM
1960custom
36
Jan 5, 2007 10:40 PM
Dan Tenn
34
Mar 8, 2006 11:04 PM
Chevythunder7578
Feb 3, 2004 10:15 PM
