Can bad GEM produce DTC B codes
Just finished my 5th tune at 280k and was using FOREScan Lite to check everything. I have some new trouble codes that popped up. B1318 Battery voltage below 9.6, B1371 courtesy light,B1869 air bags,B1982 Pats think that is a anti theft that is not an option on my vehicle. I am not sure when these codes started could have been after the tune but not sure. I would appreciate any input on this. We have a half decent day in CO today so I am going to do some inspections and get the part # on the GEM.
I did clear the codes and they did come back. Everything seems to be functioning ok. I do have some concerns with my voltage. I had a new battery fail and replaced it, the Forescan showed a low voltage code about a month ago so I installed a new alternator as the original was 20 years old. The 3 month old battery seems to lose about .5 volts in a day. This would be the second duralast gold to go bad in 8 months. Possible the alternator going bad whacked the batteries? Or I have heard tell of the GEM causing battery drain. I am going to disconnect the battery and fully charge it to check for drain. Guessing if it is a good battery there should be very little loss of voltage??? Thanks for the feed back. You guys are the best
lance65
09-13-2019 08:05 AM
