Clearing codes...not clearing
Old Sep 12, 2019 | 06:45 PM
lance65's Avatar
lance65
So I have an 88 F150 4.9/Mazda 5spd 2wd. I have been getting 3 codes. 51, 32, and 52.
I have done KOEO and KOER. KOER only 51 comes up, KOEO all 3 are present. So I have tried clearing the codes every way possible. start reading codes and pull jumper, disconnect battery turn on lights, tough +/- cables together. Problem is when I jumper the self test plug again WITHOUT having started the engine, those 3 codes are still stored. WHY?
Thank You for any help.
Old Sep 13, 2019 | 07:00 AM
subford's Avatar
subford
That is because they are not stored codes.
KOEO has nothing to do with the stored memory codes. It is an electrical check and you are not passing the electrical check.
So you can not clear KOEO codes.
The below is for KOEO and Key On Engine Running codes only:
Service Code 32 in Key On Engine Off and Key On Engine Running indicates that the EGR valve and/or EVP sensor voltage is lower than normal in the closed position. The EVP voltage is less than the closed limit voltage of 0.24 volts. Because of the preload of the EVP sensor it is very difficult to determine whether the EGR valve has malfunctioned or the EVP sensor has an abnormally high resistance.
Possible causes:
-- Poor continuity in EVP sensor harness or connectors.
-- Damaged EGR valve.
-- Damaged EVP sensor.
-- Damaged processor.
Service Codes 51 (ECT) or 54 (ACT) indicate that the corresponding sensor signal is greater than the Self-Test maximum. The maximum for ECT and ACT sensors is 4.6 volts.
Possible causes:
-- Open in harness (ACT or ECT).
-- Faulty connection.
-- Faulty sensor.
-- Faulty processor.
More than likely a cold engine.
And for 52:
NOTE:
Some vehicles are equipped with a PSPS software strategy, but do not have PSPS hardware released for the engine/vehicle application. When Service Code 52 is received in Key On Engine Off, check to see if the vehicle is equipped with PSPS. If not, disregard servicing the Code 52.
Service Code 52 indicates that the PSPS circuit is open.
Possible causes:
-- Damaged PSPS switch.
-- Open harness.
Old Sep 13, 2019 | 08:05 AM
lance65's Avatar
lance65
Thank You subford. I am starting to think the EGR system is faulty because it does run very rough and seems to stumble when engine is revved up and held at higher RPMs.
1992FordF150Custom
Jun 20, 2014 07:24 AM
Jules3084
Jun 13, 2011 11:32 AM
freegdr
1997 - 2003 F150
Feb 6, 2011 06:13 PM
kools20
Bronco II
Jul 22, 2008 07:06 PM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
