Normally I wouldn't touch a GM product but a a friend of mine was given a '56 Shivverlay 4400 dump truck that wasn't running. I've got the 265 V8 running now but it has no brakes at all. It has a master cylinder connected to the brake pedal that activates a frame mounted Bendix combination vacuum booster/master cylinder. My '58 F600 has a very similar setup except it has a Midland booster/mc.
This dump truck will only be used on a ranch and will never see a public road. Can I bypass the Bendix booster/mc and go straight from the brake pedal master cylinder to the drum brakes? The bore of the brake pedal mc is 1-1/8" if that matters. I just need enough braking to prevent the truck from rolling away.
Thanks!
I did a similar thing to a fork truck that I use in my private shop. The 1-1/4" bore master didn't development much pressure/ the pedal effort was extremely hard. I dropped down to a 1" bore, much better. I just can't justify several hundred bucks on a booster rebuild for a machine I use 6 times a year.
I bypassed the booster and the truck stops although it requires a lot of pedal pressure and it doesn't stop on a dime. It's good enough for what I need.
