That is a direct replacement into any Y Block requiring the 57 and later manifold vacuum signal.
It will fit directly into some 239's depending upon the foundry. Others, especially car blocks, will require a 14 tooth gear as well as the proper oil pump.
My old 55 F350 239 EBY block casting was a drop in swap.
How do I ? " 57 and later manifold vacuum signal. " ? I have a stock 54 with the correct engine how do I find out if this swap will work. Where can I find this info, Books has it been posted before Search this site. I have read about the different styles of ignition advance, which one or how do I tell what I have.
Casting numbers where are they and if I post them can someone on the list
tell what I have .....
I’m sorry it took me so long to post something here about the electronic ignition. A series of problems happened all at once, and I had no time to mess with these things…
The distributor is already done and installed. I took pictures of every step of the procedure. I’m almost done with the written part. I just hope there aren’t many grammar errors, since my English is not that great… Maybe someone would like to volunteer to read it over and check for those errors?
