2002 Ford Excursion 7.3L - GEM Location
I have a 2002 Ford Excursion 7.3L that developed a leak and water got into the fuse box and messed up the electronics. Most of the forums I am reading says the GEM module probably got wet and that it is bolted on the back side of the fuse box, but I removed the fuse box and there is nothing bolted to the backside of the fuse box. Is there a different location I should look at? There is a module bolted to the side wall near the fuse box, could this be it?
I have a new fuse box on the way, but if that doesnt remedy the problem I'll have to move on to something else.
Thanks in advance for you help!
