2019 PCM Reset
Old Mar 8, 2020 | 05:25 PM
Jonesy0027's Avatar
Jonesy0027
2019 PCM Reset
Howdy,
I’d like to confirm the steps to reset the PCM on my 2019.
The reason I’d like to reset is I’m not happy with the shifting of my 2019 2.7 Eco. There is a shifting delay and then ‘lurch’ onto gear and clunk around 30 mph in rush hour traffic.
Please confirm the steps to reset the PCM on my 2019 2.7 Eco.
1) Remove negative battery cable.
2) Turn in headlights to drain the remaining power for 30 minutes.
3) Connect negative battery cable.
4) Turn ignition key to accessory for 10 minutes
5) Start truck and let idle for 5 minutes.
6) Drive truck ‘non aggressively’ to learn shifting.
Old Mar 8, 2020 | 05:32 PM
ford390gashog's Avatar
ford390gashog
None of those will do anything. Do you have access to forscan? If so it's a service function, select reset adaptive learning tables. You will also find it beneficial to force reset the TCM.
Old Mar 30, 2020 | 08:14 AM
Robbgt's Avatar
Robbgt
How does one force reset the TCM? I can't seem to find it on the service function list - I found TCCM though but I think that is transfer case control module. Maybe it's named something different.
Any help is appreciated - Thanks
EDIT: @ford390gashog adding this tag so maybe you'll see this. Thank you sir.
Old Apr 10, 2020 | 07:47 AM
Robbgt's Avatar
Robbgt
Here is the list I found in service procedures. I don't see TCM.
Old Apr 10, 2020 | 10:48 AM
ford390gashog
Thats odd,I will check when I get home. It's definitely the first one on your list but there is another also and I am not seeing it listed.
Old Apr 10, 2020 | 11:01 AM
ford390gashog
This should help, whenever reset for driveabilty issues I always do TCM Module reset, PCM Transmission Adaptive Tables Reset, PCM Module Reset and PCM reset all adaptations. This will get you 100% reset!
Old Apr 10, 2020 | 11:54 AM
Robbgt's Avatar
Robbgt
Interesting - I have all the procedures you described except the TCM. Wonder if it's the adapter I'm using. I also have a slightly older version of Forscan v2.3.20 from March '19. Tried the latest version recently and my virus protection had a field day.
My adapter
Amazon Amazon
Marauder92V
6.7L Power Stroke Diesel
May 18, 2023 06:51 AM
TINITO
Apr 12, 2007 05:43 PM
paul812
1997 - 2003 F150
Sep 14, 2005 08:21 PM
cobrah
Oct 25, 2004 08:07 PM
FTE Herman
Mar 5, 2004 09:47 AM
