1990 e40d problem
Old Mar 7, 2020 | 07:45 PM
wahlturfcare's Avatar
wahlturfcare
1990 e40d problem
Iast Thursday I replaced the torque converter on my '90 superduty(7.3idi) in me 3 ur old rebuilt tranny. Well the od light on the dash is stuck on. I warrantied the neutral/multi switch just incase it was bad, changed the tack sensor since it wasn't working and the od switch. But the light still stays on and it very sluggish taking off in drive.
I can manually shift the gears with no problem.
What should I try to get it get the light to work correctly?
Old Mar 7, 2020 | 07:57 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Maybe check for fault codes?
Old Mar 7, 2020 | 08:07 PM
wahlturfcare
I checked and non pop up except for the pass code
Old Mar 7, 2020 | 08:18 PM
88n94's Avatar
88n94
You replaced the switch on the end of the shift lever but there are wires that run through the shift lever. I replaced the switch and the lever containing the wires, a normal replacement part or atleast it used to be, on my "94 F-150. That may fix your light problem but probably not the sluggish taking off in drive problem.
Old Mar 7, 2020 | 09:49 PM
wahlturfcare
I went ahead and replace both that one and the solenoid pack plug at the same time last yr and the old ones were getting kind of brittle.
ngmead
Feb 26, 2020 01:50 PM
jprix
Jun 25, 2013 10:12 PM
SALVY
Mar 19, 2009 09:31 AM
Jimmie
Dec 5, 2003 09:47 AM
AlM
1978 - 1996 Big Bronco
May 29, 2002 06:10 PM
