2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
temperature sending unit
Old Mar 5, 2020 | 08:18 PM
Pilgrim's Avatar
Pilgrim
2015 with just over 100,000 miles. Temperature gauge normally reads about midway. Recently started randomly going to bottom, then back to middle as driving. Then "coolant overheat" message appears in the message center. Truck is not running hot and appears sending unit is faulty.
Here's where it gets interesting.... sender is screwed into back of passenger side cylinder head at the bottom, just near bellhousing. It is, so far, impossible to reach with engine installed. I've tried from top, underneath on hoist, and removed tire and fender. Can just see it through fender but can reach it with a hand. Connector needs to be unplugged, then sender threaded out.
I'm ready to burn it to the ground! Pulling the engine is not a reasonable solution to replace $20 sender!
Any helpful ideas?
Old Mar 6, 2020 | 09:16 AM
alloro's Avatar
alloro
What if you first remove the exhaust manifold, will that give you enough room to get in there?
Old Mar 6, 2020 | 09:52 AM
ford390gashog's Avatar
ford390gashog
It's a 15 min job not sure why it's so hard. Just take the wheel well liner outand you can access it easily. Or just have a dealer do it if you can't.
Old Mar 8, 2020 | 12:47 PM
MBDiagMan's Avatar
MBDiagMan
Well, it could be worse. The C8 Midengine Corvette requires engine and transaxle removal to replace the accessory drive belt. A drive belt is something that must be changed eventually. The sensor is something that would usually last the life of the vehicle.
I’m not trying to minimize your problem. it sounds EXTREMELY frustrating! There have been things like this over the years and as vehicles get more reliable, repair accessibility becomes less and less of a priority. I remember the Chevy Monza of the late seventies that with a V8 required engine removal for replacement of some of the spark plugs and that was in the days when spark plugs had to be changed often.
Old Mar 8, 2020 | 09:51 PM
B-McD's Avatar
B-McD
I had a 78 Monza Spyder! Loved that thing. All you really had to do was undo the motor mounts on the one side and jack the engine up a bit to get those back two plugs. To the OP - Good luck with the fix. Hopefully the dealer or a local mechanic has a slick way to get that fixed for you.
Old Mar 9, 2020 | 06:28 PM
MBDiagMan's Avatar
MBDiagMan
B-McD is onto something. There is probably a dealer tech that has found a way to do it to beat flat rate time. Problem is finding him and getting him to share the shortcut.
Old Mar 9, 2020 | 07:11 PM
Pilgrim's Avatar
Pilgrim
Thanks for the replies. Every trip to the dealer ends in total disaster for me. Pulling the engine might be easier.
Yes, finding a tech would be great, but don't know how to do that. Will keep you posted.
Old Mar 9, 2020 | 07:17 PM
Pilgrim's Avatar
Pilgrim
I'd like you to explain your comment if possible. I already have the wheel liner out and it's difficult to even SEE it from there, and my arm (which isn't big) cannot get close to it before getting stuck. MAYBE if turbo/exhaust downpipe is removed I could TOUCH it. I taped a yellow tape marker on a stick and shoved it in there to mark it so it's easier to see but it is NOT easily accessible. It will also require working the connector off before removal in that spot. Maybe you're looking at a different year/model.?
Old Mar 15, 2020 | 02:43 PM
wb6anp's Avatar
wb6anp
What is easier, pull the engine or pull the transmission, if it near the bell housing, may need to pull the trans.
edit:
or better yet ask here. https://www.youtube.com/channel/UCN4...Llk98JddJLL51w
beatboxingboy
35
Feb 24, 2019 05:25 PM
vanHoy
13
Feb 22, 2009 08:48 PM
FordTrucksKickGM
Nov 3, 2007 04:16 PM
robin22m
Aug 9, 2005 09:11 PM
gibhart
Feb 21, 2003 09:54 AM
