Installing up-fitter switches, trying to figure out the factory wiring route.
Installed the relay box in glove box and routed the wire assy across to the fuse block.
In trying to route the wiring harness the way the factory would, and going by the push pins.
Between the glove box and the fuse block it would seem that the harness goes an upper route so the push pin attaches just below the HVAC control?
I realize there are many ways to route the assy, but being bit over **** I would like to have the exact factory look..
Any help would be greatly appreciated.
