Sponsored by: Real Truck
Upfitter switches
Old Oct 28, 2005 | 09:43 AM
SuperDutyGene's Avatar
SuperDutyGene
Smile Upfitter switches
I have an '05 F250 CC Lariat with the 6.0 Diesel. I ordered it with the trailer brake controller, but didn't know about the upfitter switches as it was one of the first '05's ordered. I was able to buy the switch block seperately, but couldn't find the plug-in for the back of the unit when I installed it. I'd like to know if the wiring harness does indeed have the plug for the switches or is it an aftermarket install and what part number I might find it under.
Thanks for your help... I love the forum.
Old Oct 28, 2005 | 09:56 AM
Fredvon4's Avatar
Fredvon4
Search upfitters here and find the posts that had all the part numbers.
It is a two part plug and play system
Part one you already have is the switch assy it self
You also need the main harness and control box (sorry I don't remember the part number)
The control box mounts inside your main glove box on the roof above the box.
The whole shebang jacks in to a port on the back of your main fuse panel in front of your left knee.
The switches just snap into the recess next to your ITBC
No real reason to pull the entire dash cover as it all can be installed from below although pulling the dash can make routing all the harness wires a bit easier.
Old Oct 28, 2005 | 09:59 AM
rwilimo's Avatar
rwilimo
You could flip to glove box down and see if the relay/fuse block is there. If it is the plug must be somewhere, if not you need 5C3Z-14A303-AA wire harness
Old Oct 28, 2005 | 10:58 AM
SuperDutyGene
Smile Upfitter Switches
Thanks for the info, I'll check it out and see if it's above the glove box.
Old Oct 28, 2005 | 11:42 AM
ktmace's Avatar
ktmace
Tapping into
Where are the electrical leads located in order to hook up & use the uppfitter switchs. Thanks for any info
Old Oct 28, 2005 | 11:58 AM
Spaznaut's Avatar
Spaznaut
Port on the main fuse box
Old Oct 28, 2005 | 12:00 PM
rwilimo's Avatar
rwilimo
Drop the fuse box (drivers side) down and you will find the 4 wires bundled together.
Old Oct 28, 2005 | 12:06 PM
ktmace's Avatar
ktmace
I must
Be blind, iv'e looked there & do not see 4 open lead wires. Help me pinpoint the location. Thanks guys
Old Oct 28, 2005 | 12:07 PM
Scott S's Avatar
Scott S
There are 4-10mm bolts holding it into the dash. The four wires are lables and color coded. 2 -10 amp and 2 -30 amp.
Old Oct 28, 2005 | 12:16 PM
ktmace's Avatar
ktmace
Im assuming
Your talking about the fuse box (4 10mm bolts) does this need to be removed for access to the leads. Man iv'e LOOKED & do not see them, unless they are behind the box
Old Oct 28, 2005 | 01:03 PM
rwilimo's Avatar
rwilimo
Yes, unbolt and pull down the fuse box, the wires are behind it.
Old Oct 28, 2005 | 02:49 PM
Scott S's Avatar
Scott S
They are right above it. Thet are bundles together with grey tape. You will see the multi colored wires. The have black dipped ends to cover the bare wire tips.
Old Oct 28, 2005 | 03:09 PM
ktmace's Avatar
ktmace
Thanks
Got it. Hooked up some 55watt halogen back-up lights to aux#1 30amp. I see tonight how there work. Thanks again guys for all the support.
Old Oct 28, 2005 | 03:48 PM
Scott S's Avatar
Scott S
Glad you got it done. Enjoy them.
Old Oct 28, 2005 | 07:56 PM
jimvh2's Avatar
jimvh2
This is the place I used to buy 3 sets for work trucks. Click the link and you can see the install process.
http://www.trademotion.com/partlocat...catalogid=3655
Edit; I see that he figured it out, maybe the link will help someone else.
