Problem With Fuel
Old Mar 2, 2020 | 08:10 PM
CodyGeorge1997's Avatar
CodyGeorge1997
Problem With Fuel
So I Have a '13 f150 stx with the 5 liter in it and the truck wont start. The thing turns over for days but wont start which leads me to believe its a fuel issue, now I've already replaced the fuel pump control module fuse with a 30 amp and relocated it once before. The issue is that last time it was a quick fix, I bought the relocation kit and moved the fuse and rewired it. Last time it was easy to identify by the melted fuse in the fuse box, but now I'm at a loss because the new fuse is fine. How possible is it that because of the beefier fuse the power went through it without blowing the fuse but shorted out either the fuel pump control module or the fuel pump itself, and how do I test that.
Old Mar 4, 2020 | 12:38 PM
steve(ill)'s Avatar
steve(ill)
When you turn the key to ON, and not START, the fuel pump should run for 3 seconds to build up pressure in the fuel rail... Listen to see if that happens... If it does NOT happen, then you need to measure the power and ground to the pump to see if there is POWER and the pump dont run, or NO POWER..
Old Mar 4, 2020 | 12:41 PM
steve(ill)'s Avatar
steve(ill)
Older trucks use to have trouble with the FPM ( fuel pump module) that tells the fuel pump when to run... Have not heard of that problem on a 2013 , but if the pump will not run... something to check..
https://www.ebay.com/itm/Dorman-601-...AAAOSwHKZdI2KJ
Old Mar 4, 2020 | 04:56 PM
2jhanna's Avatar
2jhanna
Just curious, when you did the fuse relocation kit, did you leave a fuse in slot 27, or leave it empty.
Old Mar 5, 2020 | 11:06 PM
CodyGeorge1997
No I did not because there's no wire running to that slot anymore and the slot is actually half melted from the fuse short.
Old Mar 6, 2020 | 02:07 PM
Siberexpress's Avatar
Siberexpress
Try the number 8 Relay, if there is one in number 9 use it to see if the relay is bad, I think you can also use the relays out of 4 or 6 since they are not needed to make the truck run but check you manual first (one of those is the blower motor)
CodyGeorge1997
Mar 2, 2020 08:47 PM
dustys7.3psd
Feb 11, 2019 08:03 PM
davis1
2009 - 2014 F150
Jun 28, 2018 06:12 PM
TheKhaos
Jun 21, 2013 01:04 AM
ok cowboy
Feb 14, 2009 09:38 PM
