no fuel pressure cranks wont start
Have you checked, actually pulled out and looked at, fuse 27, in fuse box above radiator. There is a known problem where the fuse and/or socket contacts will overheat and melt, without blowing the fuse.
check it and report back.
fuse 27 provides power to the fuel pump (and I believe the injectors). So if it's or socket melted, no power, no start.
