Hello!
Old Mar 2, 2020 | 08:38 AM
Ryanalofs's Avatar
Ryanalofs
Hello!
My name is Ryan and I just purchased a 1979 F-150. It has a 302 and a 4speed manual. It's a 2wd with an 8' bed and single cab. The gentleman I bought it from said it ran when he had to stop driving it 10 years ago because of his health. It was under a metal roof with just the very tip of the front of the truck sticking out. The engine is stuck and I've got some pb blaster in the cylinders since last night. So I'll be going out there today to try and loosen it up. This is my first ever project and I'm not sure which way I'm going with it, but I want to keep the engine going. It's going to take a lot of work to get it road worthy again, but I am committed. I wanted to join here to ask for tips and tricks on anything I might need help with.
Old Mar 2, 2020 | 02:19 PM
Kramercd's Avatar
Kramercd
You'll want to check out this forum for you year model https://www.ford-trucks.com/forums/forum38/. Automatic Transmission Fluid is cheap and a lot of guys use it to free up the cylinders. Welcome to FTE.
Old Mar 2, 2020 | 02:36 PM
Ryanalofs's Avatar
Ryanalofs
I broke it loose!
My '79 F-150 302 just broke loose and it runs!! I have a carb rebuild kit and a fuel pump coming for it.
Old Mar 2, 2020 | 02:45 PM
Kramercd's Avatar
Kramercd
You may want to drop and flush the fuel tank, or keep a few filters on hand.
Old Mar 3, 2020 | 04:05 AM
TomFlyer's Avatar
TomFlyer
Attachment 277521
Old Mar 3, 2020 | 05:10 AM
Ryanalofs's Avatar
Ryanalofs
Dropping the tank
What is the best way to flush the tank out?
Old Mar 3, 2020 | 06:36 AM
Kramercd's Avatar
Kramercd
Remove it. Drain it. Depending on how bad it is you may want to use a stout cleaner, or another solvent to rinse the tank. I had one bad enough on a ranger from sitting just a couple of years I took a pressure washer to the inside. Dried it best I could and put about a gallon of Acetone in it to drive the water out and give it a good rinse.
Old Mar 6, 2020 | 08:58 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Glad you got it unstuck!
Welcome aboard!
eomaynard
New Member Introductions
Sep 28, 2019 01:05 AM
Tmccauley
Jan 20, 2017 01:08 PM
lhampton
Jun 28, 2016 05:10 PM
64f100customkdp
Apr 6, 2005 03:31 PM
