Through Frame Brake fitting
Old Mar 2, 2020 | 12:19 AM
NewClimber's Avatar
NewClimber
I am struggling to understand or find the correct fitting for the calibrate brake hose that will work with my Disk Brake upgrade on my 53 F100.
I have the disk brake kit from Speedway,and it came with these brake hoses:
https://www.speedwaymotors.com/Rubbe...lQuery=6178568
Where I am having issues is how to mount the brake hose to the frame. (not the hard brake line but the flex brake hose from the disk caliper. The original drum brakes used a bulkhead type of fitting, where the outside (wheel side) of the frame, the brake hose would go though and on the inside of the frame, there was a nut to secure the brake hose to the frame. Then you could route your brake line (with a 90deg bend) into this brake hose. But the brake hose was secured to the frame. The brake hoses I have don't seem to mount to the frame anyway, the clips leave it very loose.
I seem to find -3AN bulkhead or 90 deg fittings, but nothing that is 3/8"-24 I.F. bulkhead/though frame fittings.
Am I just making this more difficult then it needs to be? Any pictures on how you routed the brake hose thought the frame to the hard brake line?
Old Mar 2, 2020 | 12:40 AM
NewClimber's Avatar
NewClimber
Sorry, just realized I put this in the wrong forum. Thx
Old Mar 2, 2020 | 09:53 AM
resonateur's Avatar
resonateur
The banjo bolt mounts the appropriate end of the brake hose to the caliper with copper washers. The other end mounts to a "tab" on the frame with a round hole, and is secured by a U-shaped brake line clip that you should be able to find at any auto parts store. If, due to modification, you don't have those tabs, you can make them and weld them to your frame at the appropriate location. Once in the tab, the metal line and flared end can be connected to that end of the brake hose. You don't use bulkhead connectors.
Old Mar 2, 2020 | 04:02 PM
BobbyFord's Avatar
BobbyFord
This should be what you need...
https://www.inlinetube.com/products/...SABEgJmoPD_BwE
Old Mar 3, 2020 | 09:43 PM
hello113's Avatar
hello113
a little pricey i probably make my own a picture is worth a thousand words drill a hole in a piece of 1/8 angle iron and file the hole to fit the hose
am i being cheep
mike
Old Mar 3, 2020 | 09:53 PM
BobbyFord's Avatar
BobbyFord
am i being cheep
mike
IDK, buy something that bolts in and fits or spend a day trying to replicate it.
My time is worth more than the cost of those brackets.
There may be cheaper vendors such as Summit Racing. My intent was to show what part to look for.
Old Mar 3, 2020 | 10:04 PM
NewClimber's Avatar
NewClimber
Hey, thx all. Even in the wrong forum, still excellent responses and ideas. Thx much.
yes, the picture is what I can do. I have the 90deg bracket and the clips, just could think on how to use it. I have a hole in my frame from the original drum brake setup, but I think I will go with this idea. Use the bracket to secure the flex line and use the hole for the hard line.
thx again for all the idea..this forum is great!!
shipwrecked
Jan 3, 2018 02:50 PM
justcruzin125
May 14, 2017 05:49 PM
Schuyles
Aug 31, 2016 10:18 AM
Otis 54
Jun 25, 2013 09:21 PM
3golfjack
Oct 26, 2011 01:58 PM
