Long crank time when hot.
Old Feb 29, 2020 | 07:01 AM
  #31
Franklin2's Avatar
Franklin2
Originally Posted by kr98664
With my truck, when fighting with a hot restart, I've noticed the starter cranking speed actually increases after a few seconds. Seems kinda odd at first, but I believe this is caused by hot fuel bubbling/foaming out of the carb and getting into the cylinders. All this extra unburnt fuel washes the oil from the cylinder walls. No oil = reduced compression = less load on the starter = faster cranking speed. However, unlike the previous example of a compression release on a motorcycle, even though the engine is spinning more quickly, that hot foamy fuel is hard to ignite and might even foul the spark plugs. Therefore, the cranking time increases.
From my experience you will find the cranking speed is increasing because the sparkplugs are not firing because they are wet with fuel. To test this, pump the accelerator once or twice before one of these hot restarts. I think you will notice your increased cranking speed time period gets longer, a function of how bad you flood the engine out. I have had vehicles with a hot cranking problem(timing too advanced) and actually got them started by flooding them a little bit so the starter could get some momentum going while the engine was flooded and not firing against the starter motor.
Old Mar 1, 2020 | 01:12 PM
  #32
jackietreehorn's Avatar
jackietreehorn
I'm not sure this problem is not caused by an improper tune. I would triple check timing, A/F ratio mixture adjustments, choke, and vacuum before resigning to the scourge of modern fuel.
Perhaps you could visit a private air field next time you are almost empty and sample some Low-Lead 110 octane aviation gasoline? If that cures all, then you know it's our fuel. If not, then we have some tuning to do.
Old Mar 1, 2020 | 03:01 PM
  #33
FuzzFace2's Avatar
FuzzFace2
You would be lucky if you can get close to the pump at the air field now days after 9/11
Dave ----
Old Mar 1, 2020 | 03:47 PM
  #34
jackietreehorn
I know of a private air field not to far from here that supposedly will sell you av gas.
"At older small airports that sell fuel, there is often a fuel pump location that planes can taxi up to. More often then not today there is simply a fuel truck. Go into the FBO and ask to purchase fuel. He will ask where your aircraft is so he can send the truck to that location. You will tell him that you have cans or a barrel in your vehicle. Generally, that is the entire discussion and he will tell you to pull around to the hanger taxiway entrance and he will send the truck to meet you. People will often drive their car to their hanger space, so there is generally an auto gate. After you are fueled up, you go back in with your fuel slip and pay your bill."
Old Mar 1, 2020 | 08:07 PM
  #35
BigBlue2's Avatar
BigBlue2
+1 on that.
For the moment, I’d hold off on mixing your own fuel blend, etc. Maybe try a different brand of fuel, as previously suggested, but I wouldn’t go much deeper than that for now.
With my truck, a big factor with a hot restart is how I position the gas pedal. I’ve found it works best if I slowly open the throttle about one third of the way. Definitely don’t pump the pedal, as that causes the accel pump to spray extra fuel (and/or foam) into the intake manifold, which makes things worse.
If the first start attempt fails, don’t release the gas pedal until after trying again. Otherwise, the accel pump sprays again, and you want to avoid that.
Yes that would be one gas pedal approach worth trying. Also try avoiding touching the gas pedal on a hot start.
Another thing to check is that the choke is wide open when hot. Adjust as necessary.
Old Mar 2, 2020 | 03:39 AM
  #36
matthewq4b's Avatar
matthewq4b
You should never have to touch the pedal on a hot start.... that may be the issue if the OP is doing that
Old Mar 3, 2020 | 09:46 AM
  #37
TheCoach's Avatar
TheCoach
I don't touch the pedal when restarting shortly after shutting it down. Usually fires right up if its less than 10-15 min or so (guessing). But if it's longer than that i usually use some pedal. Seems to crank longer if i dont. I was going to experiment next time with not giving it a press before cranking and maybe holding it down a couple inches while cranking.
Old Mar 3, 2020 | 10:21 AM
  #38
jackietreehorn
Coach what is your hot, warmed up idle speed ? ...In neutral.
Old Mar 4, 2020 | 01:25 PM
  #39
TheCoach's Avatar
TheCoach
650-700 rpm.
When i replaced the carb last summer i got it dialed in pretty decently.
Taylor Doyle
Sep 10, 2019 09:16 AM
Tim_Johnson2017
Feb 4, 2017 01:42 AM
ollirrap
16
Sep 7, 2014 04:06 PM
Turbored
Sep 11, 2004 01:30 PM
couleeman
Apr 29, 2003 01:06 AM
