Hot start=No start
Old Sep 10, 2004 | 11:38 PM
Turbored's Avatar
Turbored
Hot start=No start
Sorry if its a repost or not, Im new and I dont know how to search.
Anyways, I rescued my truck off of a farm. Now the things a basket case but it used to run pretty damn good. I brought it to school with me (4 hours) and I started having trouble with it not starting back up when Id go somewhere. So I did the tune-up thing and replaced the starter/battery/alternator and now its getting worse gas mileage and it doesnt even start when its cold half the time. Is there something I'm missing?
Edit: By the way, its a '77.
Old Sep 11, 2004 | 05:50 AM
Tranzmaan's Avatar
Tranzmaan
Starting
When you say its not starting do you mean it wont crank or cranks slow.
"OR" Its cranking and turning over just fine but it wont fire up? Hot/cold or both?
Old Sep 11, 2004 | 12:18 PM
Turbored's Avatar
Turbored
When its hot, it cranks real slow then not at all. Then I'll wait awhile (1/2 hour min) and it'll fire up.
Old Sep 11, 2004 | 01:30 PM
srercrcr's Avatar
srercrcr
I suspect the starter is getting weak. It cranks real good when cold, but once the heat of the engine builds up, it changes the tolerances in the starter windings.
I have a Pontiac (78) that has the same problem. They're notorious for this problem cause the exhaust manifold routes near the starter. I drive five miles down the road to fill my tank, and it barely cranks over. If I go ten miles...nothing.
My solution is a work in progress. I bought a mylar starter blanket that wraps around the starter to reflect heat, haven't installed it yet. Bought it from Summit Racing, $31 incl shipping. Since the Ford Six isn't notorious for this problem, and there's alot of space and free air movement, I think it's just a weak starter.
