Ranch Hand Front
Old Feb 26, 2020 | 08:46 AM
2017-350's Avatar
2017-350
Ranch Hand Front
For those of you that have done a full front replacement bumper, did the added extra weight make any differences on your truck? I have a leveled F350 and am wanting to do a full replacement. Thanks.
Old Feb 26, 2020 | 09:00 AM
17 Oaks's Avatar
17 Oaks
Not only did I have the full bumper replacement, but I had the winch option and a Warn Powerplant Winch + On Board Air system integrated. It did not make it sit any lower or change the height of the front end.
Old Feb 26, 2020 | 09:07 AM
Joe T's Avatar
Joe T
Check your front spring rate gawr.
If it is the base spring it could cause an issue but I would try it first. They also offer a heavy service spring.
Old Feb 26, 2020 | 09:38 AM
Commodorefirst's Avatar
Commodorefirst
On my f250 with the Ford lowest spring rate, I ended up sagging about 3/4" after 6 month or so. I also have dual batteries too, gasser 6.2.
I am not worried, planning on a PMF spring spacer of 1.5" with their adjustable track bar, dual PMF steering stabilizer, and new Bilst shocks all the way around. I like the softer feel of the ford springs, but sure do hate those stock shocks.
If you have any spring rate above the lowest from Ford, you should be fine.
Old Feb 26, 2020 | 09:26 PM
Lamoon78's Avatar
Lamoon78
No it will not change anything.
Old Feb 27, 2020 | 11:26 AM
Thenewboss's Avatar
Thenewboss
Smoothed out the plow package springs beautifully with zero sag to date.
Ps...don't be "that guy", get the matching rear bumper or it looks ridiculous IMO
Old Feb 27, 2020 | 04:34 PM
SARDiverDan's Avatar
SARDiverDan
Edit - I found my answer on their site
Matt M, PA
Feb 21, 2016 10:46 AM
bstopek
Mar 8, 2008 10:29 AM
emptyd
Mar 29, 2007 09:52 AM
Striker711
Jul 2, 2006 06:07 PM
John Kusanovich
1997 - 2003 F150
Nov 21, 2004 08:55 AM
