Sponsored by: Auxito
rear spring
Old Nov 19, 2004 | 07:16 PM
John Kusanovich's Avatar
John Kusanovich
rear spring
I own a 1998 F150 4x4. just broke the right rear spring in front of the rear end housing where their is a small shim.
Any history of this problem and what is the difference in a D spring and a G spring.
Thank All.
Old Nov 19, 2004 | 11:20 PM
LxMan1's Avatar
LxMan1
The load rating is probably different and may have a different ride height if mixed.
Old Nov 21, 2004 | 12:48 AM
Racerguy's Avatar
Racerguy
Hi John,
Did you get the spring replaced?
Ford has been bad the last few years about spring ratings. They don't seem to want to give out that info anymore.
Old Nov 21, 2004 | 08:55 AM
John Kusanovich
Hi,
Yes, ran out of time waiting for Ford.
Called a spring shop, the price over the top.
Found two at a large junk yard, the only difference was D to G springs.
The spring shop said to remove the steel shims at the center bolt, all have broken at the same place.
Went with new shocks. Road tested better than before.
Thanks for your reply.
JK
renegade_75
Mar 13, 2013 02:50 PM
barr75
Mar 5, 2010 09:21 PM
GHeTTo JOe
Dec 31, 2009 05:42 AM
