AOD
Old Feb 24, 2020 | 02:49 PM
SjoDon's Avatar
SjoDon
AOD
Would an aod from a 5.0 mustang be strong enough for a daily driver 240 F100?
Old Feb 24, 2020 | 03:14 PM
66v8baby's Avatar
66v8baby
Yes. Just make sure you set up the TV cable correctly.
Old Feb 24, 2020 | 04:29 PM
SjoDon's Avatar
SjoDon
I found one for $125 that came out of a mustang with 45k on the odometer.
Is this a reasonable amount?
Old Feb 24, 2020 | 04:42 PM
85e150's Avatar
85e150
What year? '88 to '93 had many of the issues sorted out. Early boxes are trouble. Since it's from a V8 that's a major plus.
Old Feb 24, 2020 | 05:30 PM
TheMonson's Avatar
TheMonson
Sounds like a steal for nearly any working transmission.
Old Feb 24, 2020 | 08:16 PM
SjoDon's Avatar
SjoDon
It is out of a 1992 model GT.
Old Feb 24, 2020 | 08:19 PM
SjoDon's Avatar
SjoDon
I just checked the listing again and it now says the tranny is shot. Not such a good deal, after all.
Old Feb 24, 2020 | 08:20 PM
Matt Bourgeois's Avatar
Matt Bourgeois
I just paid 100 for an old worn out cruise o matic. That sounds like a great deal.
Old Feb 24, 2020 | 08:32 PM
SjoDon's Avatar
SjoDon
I guess I should inquire about it.
Old Feb 25, 2020 | 10:53 AM
Matt Bourgeois
Sorry I didnt see your post before mine, if its shot I would be careful. There is a difference between a standard rebuild with new seals and clutches, and one that may require hard parts. If the transmission was abused it could get costly.
Old Feb 25, 2020 | 12:16 PM
SjoDon's Avatar
SjoDon
When I saw the part about "transmission is shot", my thought was about the same. Probably not such a good deal after all.
Old Feb 25, 2020 | 01:52 PM
Crop Duster's Avatar
Crop Duster
If you are looking for a good transmission close by. Try Car-Part.com and set the search for your zip. If you are going for an AOD or C6 it is best to get one from a donor truck if possible. You need to get the block plate that goes between the trans and engine plus all the linkages and maybe the drive shaft. Also you need to give some thought to what type of shifter you are going to use because the manual lever on the transmission is completely different between a column shifter or a floor shifter.
Old Feb 26, 2020 | 05:40 AM
jowilker's Avatar
jowilker
Hope you can find a good one. Personally I prefer an auto and one with OD much better. Dang a full growed Ford truck that can't shift it's own gears.
John
Old Feb 26, 2020 | 03:58 PM
SjoDon's Avatar
SjoDon
At this point I am considering a floor shift set-up. I will definitely need to decide soon, as I am in the process of getting p/s components together. I believe the bracket I have is for a V8 (I need one for a 240) as it is different from the pics and diagrams I have seen. Would anyone be interested in a trade? BTW, the pump and box are from a '79.
I also am wondering if I will need to modify the hump. Can someone inform me on this??
Old Feb 27, 2020 | 04:17 AM
Crop Duster
You will not have to modify the transmission tunnel. But with a C6 or AOD you will only be able to install or remove the transmission thru the front since they have an integral converter housing and there isn't enough room to remove it from underneath the truck. You can modify the center crossmember by cutting out the rivets and replacing them with bolts in order to remove the transmission separate from the engine. Also you might have to drill new holes for the rear crossmember. If on the other hand you could find a C4 that would eliminate that problem since that transmission uses a sperate converter housing. And it has a lot less internal friction than a C6 or AOD so you will end up with more usable horsepower which would be a good thing with a 240.
hooler1
Aug 13, 2013 12:49 PM
krautwolf
Dec 6, 2004 07:41 PM
glenn prentice
Nov 19, 2004 03:45 PM
mt54
May 13, 2004 12:54 PM
Capone
1978 - 1996 Big Bronco
Sep 23, 2003 08:26 AM
