Glow Plug codes
Old Feb 24, 2020 | 01:40 PM
Ranchvet's Avatar
Ranchvet
Glow Plug codes
I need help deciphering these codes that popped up. P0671, P0672, P0678. I know these are for glow plugs 1, 2, and 8 but I'm not experiencing any problems (that I know of). No CEL just the codes. Do I need to change these glowplugs or what does this mean? Thanks for the help.
Old Feb 24, 2020 | 02:13 PM
bilter's Avatar
bilter
I had code P0673 last year. No, I really didn't notice a problem when starting but it was not extremely cold that time of year. With that being said, I changed the whole bank of GPs on that side because they are not that expensive and if you are there doing it may as well do them all. Order a new harnesses as well because it is unlikely you will not damage them when pulling the boots off the GPs.
Old Feb 24, 2020 | 02:30 PM
Ranchvet's Avatar
Ranchvet
Awesome. Thanks.
Old Feb 25, 2020 | 11:00 AM
OPCJeff's Avatar
OPCJeff
You can get the glow plug harnesses on eBay for pretty cheap. It's helpful to get the removal tool too. I just spray brake cleaner on each one. It dries out the seal and makes it easier to get the harness off the plugs. Also I've found its way easier to get to the passenger side plugs by removing the inner fender well.
i picked up motorcraft plugs at O'Reilly auto. They were cheap too!
Old Feb 25, 2020 | 12:17 PM
Visurveyor's Avatar
Visurveyor
On the passenger side I cut a small u out, enough to fit my arm and see. Then epoxied some small palaces on the cut out for backing. Three screws and 'all good again. A lot easier especially if you have flares. Those Fender Wells are a bit-- to get out when U have flares. If you remove the flairs that's a whole nother can of worms you're opening up.
Old Feb 25, 2020 | 09:35 PM
xcrsp440's Avatar
xcrsp440
Google search for diesel tech Ron video on 6.0 glow plugs. Has easy tests using multi meter to determine if it is the glow plug module or the glow plugs themselves.
word of advice. Only use OEM glow plugs or control module. Can find used modules on eBay for reasonable prices.
You will wreck the harness taking it off. Get one too.
rtignor212
6.7L Power Stroke Diesel
Oct 9, 2017 06:58 AM
HAMMERDOWN103
Sep 15, 2013 11:11 PM
blueovalheart
15
Jun 29, 2012 10:48 PM
ridgebackphatty
Jan 26, 2006 12:37 PM
