Starting problems
Old Feb 23, 2020 | 02:35 PM
B R Latta's Avatar
B R Latta
Starting problems
I have a 93 F350 with a 7.3 non turbo I've put new fuel pump , filter, injectors, injectors return line & seals, glow plugs and if it sits for a couple of minutes it will only start with a shot of starting fluid, anyone have any ideas?
Old Feb 23, 2020 | 02:38 PM
gogereaver's Avatar
gogereaver
well first check for air intrusion its very common for this to cause a no start problem. next up may be a compression problem and a need for a compression test. do not use starting fluid on a diesel unless you want to replace said diesel. if you must use wd 40.
Old Feb 23, 2020 | 04:07 PM
B R Latta's Avatar
B R Latta
Are you talking about air intrusion in the fuel line?
Old Feb 23, 2020 | 04:09 PM
DarkOverCast's Avatar
DarkOverCast
Try pouring cool (not cold) water over the rear of the injector pump where the lines come out. If it starts then your ip main rotor is shot.
If it does it cold too then your either getting air in somewhere (possibly injector pump seals) or your glow plugs aren't cycling long enough.
Ether won't hurt a diesel, it's the guy behind the can that will
2002sport
24
Sep 6, 2014 10:08 PM
lartross
Mar 26, 2007 11:01 PM
catbird7
May 30, 2006 10:28 PM
96CoolCrew
Oct 1, 2003 05:15 PM
mooner
Oct 17, 2002 11:52 AM
