the reason that I suggest to leave the OEM filter as it is ... is because of the return from the filter and IF you don't have the return then it is hard to prime IF you run her out of fuel
While there is no reason that you cannot relocate it... think about access when you have problems ... no problem to just bolt it to the rail and run the lines as needed ...
