Caliper Bolts
Old Feb 19, 2020 | 04:22 PM
Jefff H's Avatar
Jefff H
Caliper Bolts
I had a caliper bolt come out and Ford does not sell just the bolt. It's a M10x1.25x25MM. I got going again using a bolt from home depot but I worry about the grade. Does anyone know the bolt specs? Will a grade 8.8 (Grade5) be sufficient?
Old Feb 19, 2020 | 04:41 PM
wb6anp's Avatar
wb6anp
Was it the guide pin? if so check with Napa.
Old Feb 19, 2020 | 04:57 PM
Truckie256's Avatar
Truckie256
Tractor supply might have it
Old Feb 19, 2020 | 05:02 PM
StonedGrey's Avatar
StonedGrey
Thats crazy FOMOCO doesnt sell just the caliper bolts. Im assuming your talking about the bolts that hold the caliper to the spindle?
What happens when a mechanic screws up and loses a caliper bolt or breaks one? They waste an entire caliper just to take the bolt out of it for replacement on another? Sounds idiotic.
I would try an auto parts store like the other said.
Old Feb 19, 2020 | 06:00 PM
Scag_Driver's Avatar
Scag_Driver
Fastenal
M10x1.25x25mm
Yellow Zinc
Class 10.9
SKU # 11116379
$4.11 Each
Old Feb 19, 2020 | 06:03 PM
HST's Avatar
HST
Check the factory torque specs. Usually caliper retaining bolts don't use much torque so probably best to get the correct grade of bolt just to be safe.
gator1gear
Dec 23, 2009 05:08 PM
69ford99
1978 - 1996 Big Bronco
Nov 13, 2006 05:07 PM
smitty7
1983 - 2012 Ranger & B-Series
Feb 16, 2005 02:34 PM
MustangGT221
Oct 6, 2003 10:41 PM
